Total posts in this thread: 8
Previous Thread This topic has been viewed 4369 times and has 7 replies Next Thread
pencilart
Desktop shortcut?
Can I make a desktop shortcut so I won't be having to open the terminal every time I want to run SweetHome3D?
[Oct 2, 2007, 11:51:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Desktop shortcut?
You can view SweetHome3D file content : it is just a command that should be run inside SweetHome3D-1.1 directory.
Maybe, renaming it as SweetHome3D.sh should make it double-clickable.
Which system are you using ?
[Oct 3, 2007, 12:32:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I'm using SuSE 10.0 and KDE for my desktop environment.
[Oct 3, 2007, 12:41:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
P.S. I renamed SweetHome3D like you said but that did not work.
[Oct 3, 2007, 12:45:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
In Konqueror, try Create New File->Link To Application...
See http://docs.kde.org/stable/en/kdebase/konqueror/making.html
[Oct 3, 2007, 1:33:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
ok, I finally got that to work. I had forgotten about the ' that should surround the path.
I also had to put the path in the work path area.
Thanks!!
[Oct 3, 2007, 9:04:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jw_e_dan
Why plenty of "Help" messages from sweet home 3D users appeared on my mailbox?!
I'm not the person who created this software!
So HELP! my mailbox is full of messages I'm not concerned with!
[Oct 3, 2007, 10:48:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You probably subscribed to this forum.
In the messages you received, there should be a link to unsubscribe to Help forum. Simply, click on it ! ;-)
[Oct 3, 2007, 10:53:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
