Total posts in this thread: 15
Posts: 15   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 14876 times and has 14 replies Next Thread
sjb007
Re: Select Hide Utility plug-in
Hi Dorin,
I saw you mention this plugin in another thread and thought "Oh. That sounds useful as I try to deconstruct my plans to try and produce acceptable planning drawings.
Unfortunately it does not work for me, although it might just be me.
Plugin installed, show an Edit menu item and a tool bar item, but clicking either one does nothing. No error message either. Just nothing.
I don't have the conflicting plugin the text mentions, and I'm running latest (7.0j)
Have you tested it with 7.0?
[Aug 19, 2022, 1:20:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I just tested the last version and it doesn't work when there is no level in the home, with the following exception:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.eteks.sweethome3d.model.Level.isViewableAndVisible()" because the return value of "utility.SelectHidePlugin.access$6(utility.SelectHidePlugin)" is null
at utility.SelectHidePlugin$1.execute(SelectHidePlugin.java:108)
Dorin, I hope this will help you to fix this bug.
[Aug 19, 2022, 3:26:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Thanks Emmanuel. I never even thought to test with a real file. I was just trying to check the plugin out on an new file with a few bits and bobs and never thought to add levels.
[Aug 19, 2022, 8:41:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
All's of You have right! The fault is mine!
So, New version 1.6 .
- fix the bug previously mentioned;
- add Chinese translation (thanks to YGIL);
Reminder: this plugin work ONLY on & with objects at selected level.
Also on Source Forge .
[Aug 20, 2022, 11:57:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks Dorin, it's possible to select objects in a home with no level now smile
[Aug 21, 2022, 10:58:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
