Total posts in this thread: 8
Previous Thread This topic has been viewed 5274 times and has 7 replies Next Thread
tomitom
Create Miniature Golf
Hello is et possible to let Create Miniature Golf tracks.
For Donate?
I Need a few tracks not all 18.
Thanks
Thomas
[Feb 9, 2019, 12:35:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Create Miniature Golf
Funny idea! smile
It's probably feasible but not so easily: straight and curved tracks can be designed with their borders thanks to rooms and walls. More complicated stuff like bumps and hollows could be designed with curved walls exported to OBJ format then reimported and rotated 90° during importation.
On the other hand, I don't see how you could design banked turns with Sweet Home 3D, but as far as I can remember, this kind of track is generally not found in a miniature Golf.
[Feb 10, 2019, 7:30:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
Challenge accepted for amusement's sake.
I made a simple example in Blender
You will need to import mini-golf.zip yourself. I haven't seen how well it looks in SH3D. It needs a lot of cleaning up as the curve conversion created way too many vertices. Worth a test drive to see if it works for you though.
Since most mini-golf is really just a bit bit of grass surrounded by a kerb with a hole in one end supporting a flag, you would be better off making the course in SH3D and just adding flags.
So here is a hole with a flag in it.
[May 4, 2019, 11:49:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
This is a mini-golf hole. I used a low wall with baseboards on both sides to give the impression of a profiled kerb. Rooms with the roof turned off to texture the floor and the start line. Add a flag and voila.
[May 6, 2019, 5:42:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your tests. Any volunteer to design the next hole?
[May 13, 2019, 11:41:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FDpaffie
Nederland
ill give it a try
Is there any minium or max size for a golf-lane ?
mine is 13 meters long ,i have made 5 simple ones
i share the sh3d file so u can see how thy are made
5 corse File with raw material
[May 13, 2019, 1:08:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bubblobill
Australia
Re: Create Miniature Golf - with a windmill
Just for fun, I threw together a windmill obstacle, because, you know, it's not minigolf without a windmill.
Feel free to improve it.
Windmill.dae
[May 22, 2019, 5:32:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FDpaffie
Nederland
well designed
i like it ,dutch flag on it some wooden shoos and tulips
good work Bubblobill
[May 22, 2019, 6:04:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
