This topic has been viewed 5244 times and has 11 replies
Thread status:
Active
ottertooth
- Member
- Country: Canada
Post
by ottertooth »
Ok, we now have found your problem. And
HERE is your solution.
Thank you. Thank you. [:)]
Result:
It does not want to cover a small section over the stairs, but this might be good enough.
Do you know how to get the floor to cover that section?
UbuntuBirdy
- Advanced Member
- Country: Switzerland
Contact:
Post
by UbuntuBirdy »
This area is not covered because of the staircaseCutOutShape defined in the model of your stairs.
The easy way to fix this would be to add a box where you wish to cover the stairs (you have to paste it at the first level).
The perfectionist way is to edit the staircaseCutOutShape in the home.xml in your sh3d file.
Pascal
Users browsing this forum: MSN [Bot]
