Previous Thread This topic has been viewed 2492 times and has 2 replies Next Thread
avnerm
Export floor texture into .obj and .mtl files
I have a home 3d model with texture on walls.
I can export the 3d model and the textures into .obj and .mtl files and open it seperately with e.g. meshlab and view the textures on the wall - good!
I want to do the same for the floor, i.e. export the floor with the background image into a 3d model.
I can export the floor, but the background image doesn't show up.
The mtl file has only the parameters illum, Ka, Kd, Ks, Ns, Ni, d but there is not texture.
Is it possible to export the floor, with the background image as texture to the floor into .obj and .mtl files?
Thanks,
Avner
[Nov 14, 2018, 9:17:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
nemetonia
Re: Export floor texture into .obj and .mtl files
Thanks,
Avner
Hello,
I think no because , floor and background are not objects.
biggrin
[Nov 14, 2018, 11:58:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
avnerm
I found out that I can export the entire 3d model with the background image into an .obj file and it opens ok with e.g. meshlab
What I want is to export only the floor with the background image.
Option1 that I tried is to place the texture in the background image
If I select the floor for export and the floor is displayed (tick Modify rooms -> Display floor), then in the exported 3d model, the background image is obscured by the floor color
If I select the floor for export and the floor is NOT displayed (untick Modify rooms -> Display floor), then the floor is not exported and the exported 3d model is empty.
Option2 that I tried is to place the texture as the floor texture of the room (Modify rooms -> Floor -> Texture -> Import -> Choose Image ...)
But it is difficult to adjust the size of the texture such that it will cover exactly the floor, even though I specify the exact Width and Height.
It would have been helpful if the floor texture would be seen in the 2d view, because then I would adjust the floor such that the texture fits it exactly.
But the texture is only seen in the 3d View panel :(
Is it possible to show the floor texture in the 2d view as well?
Thanks,
Avner
[Nov 15, 2018, 3:58:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
