KORDESTAN
how should i fix this?
hi every one i have a problem using sweet home 3d like what you can see in this image when i click ok sweet home 3d closes this problem is in 5.0 and newer versions thanks in advanced
Re: how should i fix this?
Run the installer again, and select the 32 bit option when the installer prompts you to choose the destination folder.
Rus
After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons. Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
i have fixed the issues by the same solution - reinstall SH from 64bit to 32bit ver.
