Total posts in this thread: 6
Previous Thread This topic has been viewed 4606 times and has 5 replies Next Thread
farasat
KORDESTAN
sad how should i fix this?
hi every one
i have a problem using sweet home 3d
like what you can see in this image
when i click ok sweet home 3d closes
this problem is in 5.0 and newer versions
thanks in advanced
[Oct 29, 2018, 7:56:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: how should i fix this?
Under what system did you try?
[Oct 29, 2018, 8:17:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
farasat
KORDESTAN
[Oct 30, 2018, 1:32:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Run the installer again, and select the 32 bit option when the installer prompts you to choose the destination folder.
[Oct 30, 2018, 1:50:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
farasat
KORDESTAN
applause Re: how should i fix this?
i did it and the error has fixed
I really appreciate your help
[Nov 1, 2018, 8:11:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Raevlav
Rus
After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons.
Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
i have fixed the issues by the same solution - reinstall SH from 64bit to 32bit ver.
[Dec 6, 2018, 2:56:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
