Posts: 129   Pages: 13   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 515541 times and has 128 replies Next Thread
But, for the ground? How did you create it? Is it the part of the sky image below the horizon or is it another image that you used?
The ground is textured with an image that I have created with Photoshop – an image that you can access and use, as it's used in the project file.
The ground texture is a low-res compromise between resolution and weight. This grassy ground weighs 1.2 Mb. If I could choose freely, I would choose to use a file that weighs like 200Mb, or even more. But Sh3D can't handle files of that size. It just goes white, even with 64Gb of memory assigned in the plist-file .
Anyway;
the ground plane will always be tiled if it's textured – the tiling effect is mathematically unavoidable. But if you make your grassy ground texture into a 20000x20000 cm tile ( like in the project file), then the ground will no longer appear as a matted green bathroom floor – unless you really zoom out and watch it from a 1000 meters altitude.
Please download the project file.
If you still have the same question after examining it, I shall have to make an effort to explain myself in an even simpler manner.
[Aug 30, 2018, 10:39:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I can not believe how simple your solution is for this impressive result!
I'm just waiting for Puybaret to upgrade me to Expert Member wink
[Aug 30, 2018, 10:51:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
my vote for you!
Pascal
[Aug 30, 2018, 11:33:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rontant
Singapore
Yes, absolutely, my vote as well for Cecilia to be promoted.
[Aug 31, 2018, 2:19:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Here is a result I obtained using your template Cecilia.
What do you think about it?
[Aug 31, 2018, 4:29:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lilia1996
Great job.
Really appreciate it!
[Aug 31, 2018, 4:37:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
This is one more, a sea view bedroom :)
And this is the other part of the bedroom
[Aug 31, 2018, 7:45:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Very nice!
Seems you're getting the hang of it.
Here's a tip:
Try to scale down your background image so that the sky starts at the top of the green area of the sky template, and watch what happens.
[Aug 31, 2018, 9:34:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rontant
Singapore
For the one with seaview, I think you placed the horizon way too high. Make sure the horizon and the distant mountain are within the green band in Cecilia's template.
[Sep 1, 2018, 3:46:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Very nice!
Here's a tip:
Thanks, I think now it is better :)
But the problem is that I should scale a lot the background image in order to have a large covering of the sky, and this brings a lower quality of it.
[Sep 1, 2018, 2:04:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
