Re: Sweet Home 3D 6.0
None problem for me ! .
Under Windows 10 64 bit, the 32 bit option is selected by default in the hope it will solve the problems of people who can't run Sweet Home 3D. So, pay attention to this option if you want to run Sweet Home 3D 64 bit under Windows 10.
Under my Windows 10 64 bit, Sweet Home 3D version 6.0 (x64) is installed directly in the directory "C:\Program Files (x86)" without possibility to choose the architecture if Sweet Home 3D version 5.7 (x64) is already present in the "C:\Program Files" or "C:\Program Files (x86)" directory.
EnkoNyito
Thanks for your tests. I updated Windows installer to always display the installation folder screen with an additional option to uninstall the previously installed version. Download it from SweetHome3D-6.0.beta12-windows.exe (51 MB)
None problem for me with this beta 12 ! .
I think of an important thing In the software setup interface or software installation interface, add a memory size setting option. just like SweetHome3D.l4j.ini
The default use of 0.9G in software 32 is very small, and the 64 bit 4G is too small.Slightly more complicated rendering requires 10G's memory usage.
Maybe in a future version...
In 32 bit, a higher value won't work. In 64 bit, the default max is half of the available RAM.
Is max mem 14.2 Gb?
When run in 64 bit, the working limit must be the RAM size available on your computer when Sweet Home 3D runs.
To all <?> Ubuntu users who have problems running the beta version.
Thanks to the help of UbuntuBirdy I now can try the beta version 6. Here are the program lines you need:
[Desktop Entry] Version=1.0 Name=Sweet Home 3D BETA 611 GenericName=Interior 2D design application with 3D preview Generic Name[de]=Innenraumplaner Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview Comment[de]=Innenraumplaner zum Auswählen und Platzieren von Möbeln auf einem 2D-Hausplan mit 3D-Vorschau Path=/home/hans/SweetHome3D-beta611 Exec=sh -c "/home/hans/SweetHome3D-beta611/SweetHome3D-Java3D-1_5_2" %U Icon=/home/hans/SweetHome3D-beta611/SweetHome3DIcon.png StartupNotify=true StartupWMClass=com-eteks-sweethome3d-SweetHome3D Terminal=false Type=Application Categories=2DGraphics;3DGraphics; Keywords=interior;design;2D;3D;home;house;furniture;java; MimeType=application/sweethome3d; Name[de_CH]=SweetHome3D BETA 611
Note the following: - you can change the Name and GenericName to whatever you like - you can leave out the Comment lines - you can change [de] and [de-CH] to your own language - in the path names change "hans" to your own user name - make sure that the path name /SweetHome3D-beta611/ points correctly to your file (name and location) - open a Text Editor and copy the above text - save and name the file xxx.desktop where xxx is the name you want - then copy the script to /home/hans/.local/share/applications/ - this is a hidden file, so you need to do CTRL-H to show the file
- under the start button, type SW and SH3D should show up
Thank you very much Birdy!!!
[Edit 1 times,
last edit by hansmex at Sep 25, 2018, 12:40:43 AM]
