Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 6 7 8 9 10 11 12 13 14 15 | Next Page ]
Previous Thread This topic has been viewed 1154346 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
Cec, in the macOS version based on Java 8, edit the SweetHome3D.cfg file found in the Contents/Java subfolder of Sweet Home 3D application and set the maximum memory in a line -Xmx set after the line [JVMUserOptions], writing for example -Xmx6g for 6 GB.
If the SweetHome3D.cfg file is protected, run a command like
sudo nano /Applications/Sweet\ Home\ 3D.app/Contents/Java/SweetHome3D.cfg
in a Terminal window.
[Edit 1 times, last edit by Puybaret at Sep 23, 2018, 2:18:05 PM]
[Sep 23, 2018, 2:09:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
I'm sorry to report that I can't get this version to work.
[Sep 23, 2018, 2:29:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
applause Re: Sweet Home 3D 6.0
None problem for me ! wink
[Sep 23, 2018, 6:01:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Under Windows 10 64 bit, the 32 bit option is selected by default in the hope it will solve the problems of people who can't run Sweet Home 3D. So, pay attention to this option if you want to run Sweet Home 3D 64 bit under Windows 10.
Under my Windows 10 64 bit, Sweet Home 3D version 6.0 (x64) is installed directly in the directory "C:\Program Files (x86)" without possibility to choose the architecture if Sweet Home 3D version 5.7 (x64) is already present in the "C:\Program Files" or "C:\Program Files (x86)" directory.
EnkoNyito
[Sep 23, 2018, 7:30:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Tonight, the Beta 11
If there is an old version, there will be no 32BIT/64BIT option.
[Sep 23, 2018, 8:08:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your tests. I updated Windows installer to always display the installation folder screen with an additional option to uninstall the previously installed version.
Download it from SweetHome3D-6.0.beta12-windows.exe (51 MB)
[Sep 24, 2018, 1:03:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Good idea for newbies ! biggrin
None problem for me with this beta 12 ! wink
[Sep 24, 2018, 5:49:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
I think of an important thing
In the software setup interface or software installation interface, add a memory size setting option.
just like SweetHome3D.l4j.ini
The default use of 0.9G in software 32 is very small, and the 64 bit 4G is too small.Slightly more complicated rendering requires 10G's memory usage.
[Sep 24, 2018, 10:30:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great!
I love this version.
Just one question: Is max mem 14.2 Gb?
[Sep 24, 2018, 10:56:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe in a future version...
In 32 bit, a higher value won't work. In 64 bit, the default max is half of the available RAM.
Is max mem 14.2 Gb?
When run in 64 bit, the working limit must be the RAM size available on your computer when Sweet Home 3D runs.
[Sep 24, 2018, 11:37:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
