Re: Sweet Home 3D 6.0
Beta 11 only starts like described in my last post (Ubuntu 18.04). And a hundred times longer loading times than in 5.7 (for my biggest project it takes hours...).
Pascal
Cec, in the macOS version based on Java 8, edit the SweetHome3D.cfg file found in the Contents/Java subfolder of Sweet Home 3D application and set the maximum memory in a line -Xmx set after the line [JVMUserOptions], writing for example -Xmx6g for 6 GB. If the SweetHome3D.cfg file is protected, run a command like
in a Terminal window.
[Edit 1 times,
last edit by Puybaret at Sep 23, 2018, 4:18:05 PM]
None problem for me ! .
Under Windows 10 64 bit, the 32 bit option is selected by default in the hope it will solve the problems of people who can't run Sweet Home 3D. So, pay attention to this option if you want to run Sweet Home 3D 64 bit under Windows 10.
Under my Windows 10 64 bit, Sweet Home 3D version 6.0 (x64) is installed directly in the directory "C:\Program Files (x86)" without possibility to choose the architecture if Sweet Home 3D version 5.7 (x64) is already present in the "C:\Program Files" or "C:\Program Files (x86)" directory.
EnkoNyito
Thanks for your tests. I updated Windows installer to always display the installation folder screen with an additional option to uninstall the previously installed version. Download it from SweetHome3D-6.0.beta12-windows.exe (51 MB)
None problem for me with this beta 12 ! .
