Re: Sweet Home 3D 6.0
Thanks all for your feedback.
Hans, numbers use the same decimal separator as in Sweet Home 3D, so it depends on the selected language. Prices and % look very similar to how Excel exports to CSV too. Keep in mind that CSV is a very poor format: it doesn't store the character encoding in use, doesn't oblige to use a coma or a point, doesn't state how numbers like prices should be formatted... Just open a CSV file with a text editor and you'll see it's just some lines with data separated by tabs.
ndorigatti, multi hinges aren't supported and I don't plan to add support for that. It would require to organize 3D shapes very differently in the program.
Prices was what I was missing in former versions - Great work, thanks!
Though I agree with Hansmex, that it would be great if prices could be exported to CSV without currency, so numbers could be calculated in a spreadsheet.
After some additional tests, I noticed that prices followed by user's currency and percentages are correctly interpreted as numbers by Excel and OpenOffice when the CSV file is imported. So I don't think there's a need to change the current format, moreover in case the currency is needed during a CSV import. I'm more concerned by the encoding of the CSV file. At the moment, the encoding in use is the default one on the system where the the furniture list is exported. I propose to switch to the more versatile UTF-8 encoding to avoid problems between systems and if ever you need to choose another encoding, I'll add a system property for this purpose.
By the way, this new feature
... I plan to improve the Material modification dialog box by allowing multiple selection in the materials list.
is very very practical and save much time!
Confirmed! This will be a highlight in the new version! SH3D 6.0 is one small step for Emmanuel (of course I know it's a lot of work and effort), but a big leap for mankind!
Pascal
Great work!!!!!!
I have an idea. Can allow the furniture library to support the merging of multiple objects to form a new 1 object without increasing the file size of the furniture library For example, multiple identical chairs and a dining table are grouped together.A variety of placement and color matching,File space occupying only 1 chairs and 1 tables
Singapore
I ran this beta version before on my Win 10 machine. Now it won't run anymore. Here is the log content:
Java Web Start 13.0.2.0 Using JRE version 10.0.2+13 Java HotSpot(TM) 64-Bit Server VM JRE expiration date: 16/11/18, 12:00 AM User home directory = C:\Users\Xxxxx ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- Warning: Java Web Start and Java Plug-in are deprecated and will be considered for removal in a future Java release. Please contact the developer of this content "PUYBARET EMMANUEL" and request an update for this program. Insecure property: (com.eteks.sweethome3d.deploymentInformation, Java Web Start) specified in unsigned jnlp file will not be set. Insecure property: (com.eteks.sweethome3d.applicationId, SweetHome3D#JavaWebStart) specified in unsigned jnlp file will not be set.
I’m not sure it can run with Java 10. Could you uninstall Java 10 and try with Java 8?
