Re: Sweet Home 3D 6.0
@Puybaret
The issue on the latest is that the light sources associated with the 3D model won't rotate themselves, but I have an idea to make it work: if a light source intersects with a rotated part, it sounds logical to make it rotate too.
If it works it would be nice. Otherwise, the number of articulated lights is limited at the moment.
About your test on the Slider window, this shouldn't happen simply because the windows of this model aren't supposed to go beyond the frame!
I realized this by observing the object in detail and comparing with reality. Would it be possible for the opening to be stopped by the frame? For a pocket door , we can find a trick to integrate it into the wall.
EnkoNyito
Okh, you seem to have plenty of ideas to occupy your long nights of the next winter
Enkonyito, I didn't succeed to make the articulated light work yet, but will continue to try.
I have a few ideas about how to set bounds on rotations and translations, but I don't think it will appear before the final release of version 6.0.
I had the idea to reuse the sash angles set in furniture properties, but most of the time these angles don't reflect the reality, because you can actually open some windows wider than these angles. And using this data could lead to complicated algorithms when the 3D model contains some already opened sashes, like in the open door models. I had a simpler idea in mind with additional naming conventions that would cite the bounds that should be applied to the openings. Future will tell and I prefer to focus on other features for version 6.0 at the moment.
Italia
I tryed to play with openable doors and windows, but I have a couple of issues, some on my side, some on other sides:
1 - I'm not enough good with blender to understand how and where to add the cilinders to make parts slide (but I'm learning blender) 2 - I know that paramters can be set on a text editor, but I've a lot of issues with furniture library editor, which is crashing and having weird behaviour on my OSX computer (High Sierra). When I add or remove something it becomes unusable or adds things more than once, and since I have a couple of libraries that are working and the editor can't elaborate, I'm a bit stuck on this.
I have a thing with source code of the editor but I've seen it is based on whole SweetHome and build script are Ant ( Right?) based... I need some more time to reach that !
Today, the Beta 3 allows to compute the orientation of light sources bound to the part(s) of a light able to rotate or translate.
It also introduces the two following prefixes for simple ball-arm joints: sweethome3d_ball_ sweethome3d_arm_on_ball_ these prefixes are used in the light sources of the track lights to give more freedom on lights rotations.
To let you run tests on orientable lights as well as on more doors and windows with movable parts, I finally updated the Kator Legaz and Scopia SH3F libraries, that you can download with these temporary links: 3DModels-KatorLegaz-1.6.4.beta.zip 3DModels-Scopia-1.6.4.beta.zip
[Edit 1 times,
last edit by Puybaret at Jul 13, 2018, 4:42:57 PM]
Thanks for your feedback. I'm astonished by your report because I didn't change anything on textures management. Please, send me a simple SH3D file showing your issue.
The light sources of the articulated lights follow the changes well.
Would it be possible to highlight the moving parts or the rotation/translation axes in the 3D preview as for the material changes?
EnkoNyito
Singapore
Emmanuel, I have sent you via email the file. It's 8MB in size though. I hope the mail gets through.
