Re: Sweet Home 3D 6.0
While making a few renders for another thread, I noticed that after finishing the rendering, SH3D keeps using all 6 cores of my processor at (close to) 100%, just as it does while rendering.
This heavy usage only stopped when I shut down SH3D.
I also noticed that when applying a transparent texture to vertical blinds, the blinds are shown as completely black in the 3D preview window. Is this a regression? We also had this in some earlier version.
(beta 6.11 under Ubuntu 18.04)
EDIT Meanwhile I installed version 6. - Processor stops at end of rendering. (same file & settings as before) - Transparency still shown as black.
[Edit 2 times,
last edit by hansmex at Oct 13, 2018, 11:22:50 AM]
In SH3D 6.0 the GPU load for the 3D view (only virtual visitor) is reeeeally high, strange high. In fact it's higher than in any other application, even higher than in complex 3D games or benchmark tests. It's much higher than in 5.7 or any older versions. This is not a big issue, because the max temperature of the polaris chip is approximately 90° C and atm the actual temperature is at 55°, but it's a noisy (because of the fan) one... Normally the temperature of the GPU is not higher than 40°.
Pascal
I'm agree with hans and Ubuntu about 3D renderings.
With the final 6.0, I find that a 3D rendering is too important for the main processor and not for the GPU.
Here are the results on my PC :
Tested with Core i7-4790 - RAM 16Go - GC : GeForce 970 GTX 4 Go CG is 4 years old, is this the weakest link ???
@Puybaret : what can you do to ameliorate this point ? .
The problem on my system does not occur while rendering, only in the 3D view in virtual visitors mode while "walking around".
Pascal
None problem in the 3D view in virtual visitors mode while "walking around", whatever the project.
It seems that each PC has own problem. .
Congratulations on the release of 6.0. Quite remarkable. Still working my way through all the new features in different settings. Only significant problem is that I have to redesign my sky textures and models completely... . So, THANKS!
As for processor usage: Except when testing with giant sky textures, I have not noticed any slowdown with 6.0 under Windows. Compared to previous versions, it seems pretty similar to me. I (mostly) run SH3D on a slow computer with no extra headroom, but as long as I stay away from too big models and to much creative use of light, 6.0 seems pretty quick to me. In fact, I am pleasantly surprised that the richness in features work without noticeable slowdown. But yes, in certain circumstances, SH3D will grab every resource available. Just like other software when doing certain tasks.
Hi As usual i am missing something, i dont see how to make an object that can be deformed, the window obj's i have made recently do not have this :- All help welcome Mike
Thank you all for your feedback. It’s possible that the GPU has more work in this version because of the lighter management of the frustum front and back distances, but this should also lead to more fluid moves in the 3D view.
Mike, your own 3D models can’t be deformed without modification. Please read this post for more information.
Hi Emmanuel Thx for the response, i did see the topic but the pictures did not fully explain it and unfortunately its all written in greek, as is the topic about showing the sash openings, so i guess i'll just use groups. Mike
