Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 11 12 13 14 15 16 17 18 19 20 | Next Page ]
Previous Thread This topic has been viewed 729181 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
The final release of version 6.0 is out. Enjoy! smile
The portable version will be released a little later once I'll gather more translations.
Thanks all for your tests, your feedback, your support and... your patience.
[Oct 12, 2018, 1:54:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
applause Re: Sweet Home 3D 6.0
I don't think the translation is right here.
选择唯一可见楼层(Make select level the only viewable one)
It should be changed to
只可见该楼层
[Oct 12, 2018, 5:59:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
While making a few renders for another thread, I noticed that after finishing the rendering, SH3D keeps using all 6 cores of my processor at (close to) 100%, just as it does while rendering.
This heavy usage only stopped when I shut down SH3D.
I also noticed that when applying a transparent texture to vertical blinds, the blinds are shown as completely black in the 3D preview window. Is this a regression? We also had this in some earlier version.
(beta 6.11 under Ubuntu 18.04)
EDIT
Meanwhile I installed version 6.
- Processor stops at end of rendering. (same file & settings as before)
- Transparency still shown as black.
[Edit 2 times, last edit by hansmex at Oct 13, 2018, 11:22:50 AM]
[Oct 12, 2018, 3:46:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
In SH3D 6.0 the GPU load for the 3D view (only virtual visitor) is reeeeally high, strange high. In fact it's higher than in any other application, even higher than in complex 3D games or benchmark tests. It's much higher than in 5.7 or any older versions.
This is not a big issue, because the max temperature of the polaris chip is approximately 90° C and atm the actual temperature is at 55°, but it's a noisy (because of the fan) one...
Normally the temperature of the GPU is not higher than 40°.
Pascal
[Oct 13, 2018, 12:57:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
confused Re: Sweet Home 3D 6.0
I'm agree with hans and Ubuntu about 3D renderings. wink
With the final 6.0, I find that a 3D rendering is too important for the main processor and not for the GPU. biggrin
Here are the results on my PC :
Tested with Core i7-4790 - RAM 16Go - GC : GeForce 970 GTX 4 Go
CG is 4 years old, is this the weakest link ??? biggrin
@Puybaret : what can you do to ameliorate this point ?
[Oct 13, 2018, 6:28:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
biggrin Re: Sweet Home 3D 6.0
WINDOWS version does not have this problem.
[Oct 13, 2018, 10:27:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
The problem on my system does not occur while rendering, only in the 3D view in virtual visitors mode while "walking around".
Pascal
[Oct 13, 2018, 10:59:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
None problem in the 3D view in virtual visitors mode while "walking around", whatever the project. wink
It seems that each PC has own problem. biggrin
[Oct 13, 2018, 11:19:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Congratulations on the release of 6.0. Quite remarkable. Still working my way through all the new features in different settings. Only significant problem is that I have to redesign my sky textures and models completely... smile. So, THANKS!
As for processor usage: Except when testing with giant sky textures, I have not noticed any slowdown with 6.0 under Windows. Compared to previous versions, it seems pretty similar to me. I (mostly) run SH3D on a slow computer with no extra headroom, but as long as I stay away from too big models and to much creative use of light, 6.0 seems pretty quick to me. In fact, I am pleasantly surprised that the richness in features work without noticeable slowdown. But yes, in certain circumstances, SH3D will grab every resource available. Just like other software when doing certain tasks.
[Oct 13, 2018, 5:15:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi
As usual i am missing something, i dont see how to make an object that can be deformed, the window obj's i have made recently do not have this :-
All help welcome
[Oct 14, 2018, 11:56:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
