Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 1135020 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
Still have not been able to find any anomalies in 6.0. No craches, no beta issues.
..have an idea to make it work: if a light source intersects with a rotated part, it sounds logical to make it rotate too...
Should be interesting.
.. better to wait for the final release of version 6.0...
And wait until I get my head around all of these very nice new properties for SH3D models smile. It seems to me that it is now possible to create very good models that will work in any context AND have extra custom features in SH3D. Your work on the axes and pivot points of models, really changes the approach to making good models for SH3D.
Actually I started editing the SVG stuff using proper SVG figures and also changing pressentation slightly now that I know a bit more about SVG paths (and maybe ditching .pdf for proper .html to stick with the non-proprietary approach). Thought of adding something about
- multiple light sources,
- illustrations on window/door properties (sashes/wall distance),
- how to simplify models using your 261 approach,
- and maybe something about Ceciliabr's interesting high-res testing in thread 8292 (but advanced use of lights and optical density may be more in the realm of the rendering/light experts),
- obj g/o prefix sweethome3d_window_mirror and now a full catalogue of excitig new prefixes,
- possibly also price information depending on where 6.0 goes - do not think I want to mention that until I know it will bepart of the default interface (even if it is fully available for advanced users already),
- and maybe mention something about Home.xml. For anyone having edited .xml before, it really is a super fast way of changing furniture properties directly without the FurniturePropertyCatalogue detour.
That said - I will be happy to sum up notes into the mini-guide as a reference (which basically is what it is), if anyone has wishes for putting other cheat-sheets into the manual...
Anyway, I am always surprised when I see your priorities for SH3D development. Good news is that they are always pleasant surprises... I really did not see the 6.0 features coming...
Thanks and good luck with the rest of the implementation.
[Jul 8, 2018, 7:57:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Puybaret
The issue on the latest is that the light sources associated with the 3D model won't rotate themselves, but I have an idea to make it work: if a light source intersects with a rotated part, it sounds logical to make it rotate too.
If it works it would be nice. Otherwise, the number of articulated lights is limited at the moment.
About your test on the Slider window, this shouldn't happen simply because the windows of this model aren't supposed to go beyond the frame!
I realized this by observing the object in detail and comparing with reality. Would it be possible for the opening to be stopped by the frame?
For a pocket door , we can find a trick to integrate it into the wall.
EnkoNyito
[Jul 9, 2018, 4:57:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Okh, you seem to have plenty of ideas to occupy your long nights of the next winter wink
Enkonyito, I didn't succeed to make the articulated light work yet, but will continue to try.
I have a few ideas about how to set bounds on rotations and translations, but I don't think it will appear before the final release of version 6.0.
[Jul 9, 2018, 10:04:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
Is one if this ideas involving the stash angle that can be set when creating a door in forniture catalog?
[Jul 10, 2018, 8:05:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I had the idea to reuse the sash angles set in furniture properties, but most of the time these angles don't reflect the reality, because you can actually open some windows wider than these angles. And using this data could lead to complicated algorithms when the 3D model contains some already opened sashes, like in the open door models.
I had a simpler idea in mind with additional naming conventions that would cite the bounds that should be applied to the openings. Future will tell and I prefer to focus on other features for version 6.0 at the moment.
[Jul 10, 2018, 11:29:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
I tryed to play with openable doors and windows, but I have a couple of issues, some on my side, some on other sides:
1 - I'm not enough good with blender to understand how and where to add the cilinders to make parts slide (but I'm learning blender)
2 - I know that paramters can be set on a text editor, but I've a lot of issues with furniture library editor, which is crashing and having weird behaviour on my OSX computer (High Sierra). When I add or remove something it becomes unusable or adds things more than once, and since I have a couple of libraries that are working and the editor can't elaborate, I'm a bit stuck on this.
I have a thing with source code of the editor but I've seen it is based on whole SweetHome and build script are Ant ( Right?) based... I need some more time to reach that !
[Jul 11, 2018, 2:22:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Today, the Beta 3 allows to compute the orientation of light sources bound to the part(s) of a light able to rotate or translate.
It also introduces the two following prefixes for simple ball-arm joints:
sweethome3d_ball_
sweethome3d_arm_on_ball_
these prefixes are used in the light sources of the track lights to give more freedom on lights rotations.
To let you run tests on orientable lights as well as on more doors and windows with movable parts, I finally updated the Kator Legaz and Scopia SH3F libraries, that you can download with these temporary links:
3DModels-KatorLegaz-1.6.4.beta.zip
3DModels-Scopia-1.6.4.beta.zip
[Edit 1 times, last edit by Puybaret at Jul 13, 2018, 2:42:57 PM]
[Jul 13, 2018, 2:30:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rontant
Singapore
Emmanuel, I tried the Beta3 and it is unable to render my human characters. Their textures are lost.
[Jul 14, 2018, 5:35:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback. I'm astonished by your report because I didn't change anything on textures management.
Please, send me a simple SH3D file showing your issue.
[Jul 14, 2018, 12:14:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The light sources of the articulated lights follow the changes well.
Would it be possible to highlight the moving parts or the rotation/translation axes in the 3D preview as for the material changes?
EnkoNyito
[Jul 14, 2018, 1:04:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
