Re: Sweet Home 3D 6.0
When I open the file, the cement texture is repeated approx 4 times vertically. When I import the cement texture and apply it on the wall left of the entrance (texture height 365.9 cm) it applies "correctly", without repetition, on the wall. When I apply the texture (texture height still 365.9 cm)on the central left wall, the texture repeats 3 times. When I modify the texture height to 900 cms (same as wall height) the texture applies correctly. When I walk the virtual visitor to the center of the courtyard and look around, parts of the wall show the cement texture repeat itself 3x, parts 4x, and parts are shown correctly.
Strange...
Done under Ubuntu 18.04.
[Edit 1 times,
last edit by hansmex at Oct 9, 2018, 5:42:40 PM]
Cec, I compared how your file renders with Sweet Home 3D 6 Beta and Sweet Home 3D 5.0 (won't work with Mac OS X ≥ 10.13) and didn't notice any visual difference : same wall sides where the texture spreads from the top to the bottom and same ones where the texture pattern is smaller. As each wall side stores the size of the texture applied on it, it's possible to mix the same imported texture image at different size (I speak about size, not scale) if you change that size at different moments. Keep also in mind that a SH3D file contains everything it needs to render itself, even if I guess that you proposed the texture image to let us test it.
As a conclusion, here's a tip that few of us know: if you want to copy a texture from a file to another one, display that texture in Texture dialog box like if you wanted to change the texture of a wall or a material, press OK to add it in the recent textures list, then choose the object on which you want to apply the texture, display its Texture dialog box and choose the texture in the recent ones lis. Et voilà! Not super handy, not a behavior I thought about when I programmed Sweet Home 3D, but actually a nice tip
I'm obviously very bad at explaining things. The thing is: If you don't have the texture loaded and sized prior to opening the linked file, the texture will of course be displayed correctly, as it also will if I resize the texture correctly prior to opening the project file. This texture has been used in another project later, and given a smaller size, so in the texture library this texture is sized to 365.9 cm. And that's why the problem occurs.
As hansmex correctly points out:
When I open the file, the cement texture is repeated approx 4 times vertically. When I import the cement texture and apply it on the wall left of the entrance (texture height 365.9 cm) it applies "correctly", without repetition, on the wall. When I apply the texture (texture height still 365.9 cm)on the central left wall, the texture repeats 3 times. When I modify the texture height to 900 cms (same as wall height) the texture applies correctly. When I walk the virtual visitor to the center of the courtyard and look around, parts of the wall show the cement texture repeat itself 3x, parts 4x, and parts are shown correctly. Strange...
That's exactly what I encountered. All occurrences of the texture is wrong; apart from the ones I have already fixed, using the method I described.
This goes for all textures that are already in the texture library and holding different sizes than what are used in the project file. So if I use a texture in a project, and then resize it for use in a newer project, V6 will not display it correctly when the older project is opened. My linked project file (as most of my projects), was created with V5.3 ( because of the hither-yon issue).
This is not a big deal, as long as I'm aware of it, but it needs to be pointed out.
Could you send me a demo file with textures that don't behave as in version 5.7?
Found a temp-file that you can look at. It's too big for my mail server, but here it is: PCTY_LVLS.sh3d L
Texture map UV on some walls is wrong. But I think we can ignore this problem. Maybe you changed the software version. This problem has never been encountered in normal use.
Bug or anomaly ?
Yesterday, during the building of my latest model, I saw an 'error' in a room. (?)
It appears on a part of wall (blue Arrow in 3D view). The room at right has yellow Walls and light blue baseboard. The main room has orange walls and light wooden baseboard. So, I saw a part of wall always 'yellow' (red Arrow in 3D view).
=> On the twice rooms, I cannot use the option "recompute the room" (red frame). Why ?
Is it only on the release 6.0 and the previous ???
@Emmanuel I notice some new, unwanted behaviour. When I import a model, the icon in the 2D view is shown enlarged 2-3 times its original size. Top-left corner is where it should be, but large part of the rest of the image disappears.
(Under Ubuntu 18.04)
(edit) Somehow, I get the feeling that the icon problem is connected with the incorrect 3D render in Q1 and Q2 that I mentioned earlier. These also seem to show the top-left part of the "real" image.
Also, when I open Cecilia's "shed" file, or one of my own files, the icons are incorrect. Strange..
I tested this with the Envidia driver recommended for my video card, and with the X-driver that's native to Ubuntu. Both give the same results.
[Edit 4 times,
last edit by hansmex at Oct 11, 2018, 3:24:52 PM]
@Hans Does this issue appear with both video card drivers, the one offered by Ubuntu (Open Source) and the one offered by Nvidia (proprietarily)? I ask this question because I am not able to reproduce this issue on my Ubuntu 18.04.
Pascal
OMG! I'm so sorry! Who can read is in the advantage... I have to stop doing multiple things at the same time...
Pascal
The portable version will be released a little later once I'll gather more translations.
Thanks all for your tests, your feedback, your support and... your patience.
