Re: Sweet Home 3D 6.0
Cec, I couldn't reproduce the 3D error during furniture wizard. I already saw it happen rarely, but I could force the error myself during the past days. I even tried to press <enter> to continue very quickly between each step, but even this behavior didn't cause problems. Does it happen each time in your case?
I also successfully tested the copy/paste between projects. I suspect you tried to copy something from Sweet Home 3D 5.7 then paste it in a new project running with Sweet Home 3D 6.0 Beta, in which case it can't work. Copy/Paste works only within the same Sweet Home 3D program.
Hans, I couldn't reproduce your issue too. There must be an additional parameter...
More or less each time. I can reproduce this error every time I'm importing bigger models. Not so often with smaller. It would be nice if continue didn't work until it was safe to use.
Of course. I even saved the linked project with v6 and re-opened it. After copying a spotlight, the only option I get is to Paste Style – Paste is greyed out on the menu.
Well, then I also tell my experiences with BETA14. I tested with JRE8,10 and 11 on Ubuntu 18.04. I really can not complain, everything is going as expected. I also tried to reproduce the problems mentioned here on my system, but apparently my system does not want any problems, at least all the processes that have caused other problems work perfectly well for me. The only limitation on my system is still that I have to start SH3D via Terminal, and only the 1_5_2 script works. This also means that I can not experience java3d in version 1.6... With JRE10 and 11 I also had to insert
into the script, because without this entry various objects in the UI are not recognizable. Oh man, I'm really looking forward to the final version of SH3D 6!!!
Pascal
...what I forgot: with JRE10 and 11 the difference between the -Xmx entry and what SH3D displays has gone.
Pascal
Could you send me a demo file with textures that don't behave as in version 5.7?
Found a temp-file that you can look at. It's too big for my mail server, but here it is: PCTY_LVLS.sh3d Look at the outer wall texture. The height is set to 900 cm. I have to open the modify walls window, find the texture ( cement_13) and open the modify texture window, and then, without modifying anything, just click ok – not cancel. Close the modifiers and the texture will display correct.
EDIT:
Forgot: First load texture cement_13.jpg and set height to 365.9 cm. Do this prior to opening the .sh3d-file.
[Edit 2 times,
last edit by Ceciliabr at Oct 9, 2018, 1:37:04 PM]
EDIT:
On Ubuntu 18.04 I have to reselect the texture of both sides of the wall before the texture will display correct.
Pascal
When I open the file, the cement texture is repeated approx 4 times vertically. When I import the cement texture and apply it on the wall left of the entrance (texture height 365.9 cm) it applies "correctly", without repetition, on the wall. When I apply the texture (texture height still 365.9 cm)on the central left wall, the texture repeats 3 times. When I modify the texture height to 900 cms (same as wall height) the texture applies correctly. When I walk the virtual visitor to the center of the courtyard and look around, parts of the wall show the cement texture repeat itself 3x, parts 4x, and parts are shown correctly.
Strange...
Done under Ubuntu 18.04.
[Edit 1 times,
last edit by hansmex at Oct 9, 2018, 5:42:40 PM]
Cec, I compared how your file renders with Sweet Home 3D 6 Beta and Sweet Home 3D 5.0 (won't work with Mac OS X ≥ 10.13) and didn't notice any visual difference : same wall sides where the texture spreads from the top to the bottom and same ones where the texture pattern is smaller. As each wall side stores the size of the texture applied on it, it's possible to mix the same imported texture image at different size (I speak about size, not scale) if you change that size at different moments. Keep also in mind that a SH3D file contains everything it needs to render itself, even if I guess that you proposed the texture image to let us test it.
As a conclusion, here's a tip that few of us know: if you want to copy a texture from a file to another one, display that texture in Texture dialog box like if you wanted to change the texture of a wall or a material, press OK to add it in the recent textures list, then choose the object on which you want to apply the texture, display its Texture dialog box and choose the texture in the recent ones lis. Et voilà! Not super handy, not a behavior I thought about when I programmed Sweet Home 3D, but actually a nice tip
I'm obviously very bad at explaining things. The thing is: If you don't have the texture loaded and sized prior to opening the linked file, the texture will of course be displayed correctly, as it also will if I resize the texture correctly prior to opening the project file. This texture has been used in another project later, and given a smaller size, so in the texture library this texture is sized to 365.9 cm. And that's why the problem occurs.
As hansmex correctly points out:
When I open the file, the cement texture is repeated approx 4 times vertically. When I import the cement texture and apply it on the wall left of the entrance (texture height 365.9 cm) it applies "correctly", without repetition, on the wall. When I apply the texture (texture height still 365.9 cm)on the central left wall, the texture repeats 3 times. When I modify the texture height to 900 cms (same as wall height) the texture applies correctly. When I walk the virtual visitor to the center of the courtyard and look around, parts of the wall show the cement texture repeat itself 3x, parts 4x, and parts are shown correctly. Strange...
That's exactly what I encountered. All occurrences of the texture is wrong; apart from the ones I have already fixed, using the method I described.
This goes for all textures that are already in the texture library and holding different sizes than what are used in the project file. So if I use a texture in a project, and then resize it for use in a newer project, V6 will not display it correctly when the older project is opened. My linked project file (as most of my projects), was created with V5.3 ( because of the hither-yon issue).
This is not a big deal, as long as I'm aware of it, but it needs to be pointed out.
Texture map UV on some walls is wrong. But I think we can ignore this problem. Maybe you changed the software version. This problem has never been encountered in normal use.
