Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 10 11 12 13 14 15 16 17 18 19 | Next Page ]
Previous Thread This topic has been viewed 734995 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
Could you send me a demo file with textures that don't behave as in version 5.7?
I have unfortunately already re-textured all the walls and saved the project with v6.
2) I don't think it's very serious, moreover in the 3rd step of the furniture import wizard.
This IS serious:
This happens if you press Continue too early.
3) The stop button starts to warn you once the rendering has already lasted 30s.
I noticed. But the warning pop-up is hidden behind the render window.
[Oct 5, 2018, 8:30:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
smile Re: Sweet Home 3D 6.0
At this day, none problem with v6 beta14 ! applause
1. Furniture import wizard : OK
2. Renderings
with standard Q4 : OK.
with PVR 1.5 Q4 : OK (0 to 100%).
=> estimated time given at 1% : 08h23mn. sad
=> estimated time given at 2% : 07h01mn. biggrin
=> estimated time given at 3% : 08h13mn ??? confused
[Oct 6, 2018, 6:29:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
That's what I noticed, so no problem for me.
But... I did notice some strange behavior. When I make a quick render using Q1, I get a different picture from what I expect. (See screenshot). However, when I make the same render in Q3 everything is normal.
[Edit 1 times, last edit by hansmex at Oct 6, 2018, 10:30:50 AM]
[Oct 6, 2018, 10:04:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
@ Puybaret
Can you check copy/paste from other projects?
I'm unable to copy /paste anything from this project with beta 14.
In v5.7 it works fine.
[Oct 7, 2018, 12:13:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cec, I couldn't reproduce the 3D error during furniture wizard. I already saw it happen rarely, but I could force the error myself during the past days. I even tried to press <enter> to continue very quickly between each step, but even this behavior didn't cause problems. Does it happen each time in your case?
I also successfully tested the copy/paste between projects. I suspect you tried to copy something from Sweet Home 3D 5.7 then paste it in a new project running with Sweet Home 3D 6.0 Beta, in which case it can't work. Copy/Paste works only within the same Sweet Home 3D program.
Hans, I couldn't reproduce your issue too. There must be an additional parameter...
[Oct 7, 2018, 5:43:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
More or less each time. I can reproduce this error every time I'm importing bigger models. Not so often with smaller.
It would be nice if continue didn't work until it was safe to use.
Of course. I even saved the linked project with v6 and re-opened it. After copying a spotlight, the only option I get is to Paste StylePaste is greyed out on the menu.
[Oct 8, 2018, 11:01:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
Well, then I also tell my experiences with BETA14. I tested with JRE8,10 and 11 on Ubuntu 18.04.
I really can not complain, everything is going as expected. I also tried to reproduce the problems mentioned here on my system, but apparently my system does not want any problems, at least all the processes that have caused other problems work perfectly well for me.
The only limitation on my system is still that I have to start SH3D via Terminal, and only the 1_5_2 script works. This also means that I can not experience java3d in version 1.6...
With JRE10 and 11 I also had to insert
-Dswing.defaultlaf = javax.swing.plaf.metal.MetalLookAndFeel
into the script, because without this entry various objects in the UI are not recognizable.
Oh man, I'm really looking forward to the final version of SH3D 6!!!
Pascal
[Oct 8, 2018, 5:18:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
...what I forgot: with JRE10 and 11 the difference between the -Xmx entry and what SH3D displays has gone.
Pascal
[Oct 8, 2018, 5:21:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Found a temp-file that you can look at. It's too big for my mail server, but here it is: PCTY_LVLS.sh3d
Look at the outer wall texture. The height is set to 900 cm. I have to open the modify walls window, find the texture ( cement_13) and open the modify texture window, and then, without modifying anything, just click ok – not cancel. Close the modifiers and the texture will display correct.
EDIT:
Forgot:
First load texture cement_13.jpg and set height to 365.9 cm. Do this prior to opening the .sh3d-file.
[Edit 2 times, last edit by Ceciliabr at Oct 9, 2018, 11:37:04 AM]
[Oct 9, 2018, 11:28:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
EDIT:
Forgot:
On Ubuntu 18.04 I have to reselect the texture of both sides of the wall before the texture will display correct.
Pascal
[Oct 9, 2018, 1:39:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
