Re: Sweet Home 3D 6.0
I just copied the new files in the beta-11 directory, thinking that was all I needed to do. I forgot that I needed the Xmx-thing to change memory usage.
Rest assured, I didn't hit myself overly hard. :-)
I have been doing some extensive testing of v6 β14 using OSX Mojave, and have found a couple of things I would like to mention:
1) β14 does not read textures correct for files created with older versions:
2) When importing furniture, the status of the Continue-button changes before the model has loaded.
3) When cancelling a rendering by mistake, the rendering just stops without offering a chance to reconsider your choice. It's very easy to cancel a render process unintentionally and loose hours of rendering, so this is important!
3) Rendering stopping without asking can happen also under other OS's, especially in the beginning of the rendering process.
Cecilia, thanks for your report.
1) Could you send me a demo file with textures that don't behave as in version 5.7?
2) I don't think it's very serious, moreover in the 3rd step of the furniture import wizard.
3) The stop button starts to warn you once the rendering has already lasted 30s.
At this day, none problem with v6 beta14 !
1. Furniture import wizard : OK
2. Renderings with standard Q4 : OK.
with PVR 1.5 Q4 : OK (0 to 100%). => estimated time given at 1% : 08h23mn. => estimated time given at 2% : 07h01mn. => estimated time given at 3% : 08h13mn ???
That's what I noticed, so no problem for me.
But... I did notice some strange behavior. When I make a quick render using Q1, I get a different picture from what I expect. (See screenshot). However, when I make the same render in Q3 everything is normal.
[Edit 1 times,
last edit by hansmex at Oct 6, 2018, 10:30:50 AM]
