Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 9 10 11 12 13 14 15 16 17 18 | Next Page ]
Previous Thread This topic has been viewed 1177901 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
Hans, if you use the Linux version you should change the launch script to add -Xmx... max memory parameter.
I'm going to set it to -Xmx2g in the final version of the 64 bit version.
[Oct 5, 2018, 12:49:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You stupid boy!!! <hitting myself on the head>
[Oct 5, 2018, 1:03:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
Don't worry, Hans! Go back and see what I did with Beta 11... laughing
Pascal
[Oct 5, 2018, 1:47:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I just copied the new files in the beta-11 directory, thinking that was all I needed to do. I forgot that I needed the Xmx-thing to change memory usage.
Rest assured, I didn't hit myself overly hard. :-)
[Oct 5, 2018, 2:01:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I have been doing some extensive testing of v6 β14 using OSX Mojave, and have found a couple of things I would like to mention:
1) β14 does not read textures correct for files created with older versions:
2) When importing furniture, the status of the Continue-button changes before the model has loaded.
3) When cancelling a rendering by mistake, the rendering just stops without offering a chance to reconsider your choice. It's very easy to cancel a render process unintentionally and loose hours of rendering, so this is important!
Part from this: All thumbs up!
[Oct 5, 2018, 5:34:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
3) Rendering stopping without asking can happen also under other OS's, especially in the beginning of the rendering process.
[Oct 5, 2018, 5:51:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cecilia, thanks for your report.
1) Could you send me a demo file with textures that don't behave as in version 5.7?
2) I don't think it's very serious, moreover in the 3rd step of the furniture import wizard.
3) The stop button starts to warn you once the rendering has already lasted 30s.
[Oct 5, 2018, 9:03:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I have unfortunately already re-textured all the walls and saved the project with v6.
This IS serious:
This happens if you press Continue too early.
I noticed. But the warning pop-up is hidden behind the render window.
[Oct 5, 2018, 10:30:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
smile Re: Sweet Home 3D 6.0
At this day, none problem with v6 beta14 ! applause
1. Furniture import wizard : OK
2. Renderings
with standard Q4 : OK.
with PVR 1.5 Q4 : OK (0 to 100%).
=> estimated time given at 1% : 08h23mn. sad
=> estimated time given at 2% : 07h01mn. biggrin
=> estimated time given at 3% : 08h13mn ??? confused
[Oct 6, 2018, 8:29:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
That's what I noticed, so no problem for me.
But... I did notice some strange behavior. When I make a quick render using Q1, I get a different picture from what I expect. (See screenshot). However, when I make the same render in Q3 everything is normal.
[Edit 1 times, last edit by hansmex at Oct 6, 2018, 12:30:50 PM]
[Oct 6, 2018, 12:04:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
