Re: Sweet Home 3D 6.0
I can't use the *.jnlp of course, but I played with the test file you provided.
The reason why I wanted the text to have a fixed place, was the fact that I read in the forum that many people use SH3D to obtain a building permit. In such cases it would be interesting to have a fixed text block at the right or in the bottom right, where all the drawing info goes.
Of course, if I add or delete text the text block changes in size. Preferably, for latin script, the text block should be fixed at top-left, for arabic script at top-right.
After reading Cecilia's posts about horizons, skies and backgrounds, I decided I had to try it out for myself. It works very nice.
Two things: 1 - I find the % for the X-offset confusing, and would prefer degrees for orientation. 2 - I noticed that in the Sky-Texture dialogue, the program doesn't remember the search text, as it does in other texture dialogues.
Thanks for your tests and feedback. The JS viewer simply needed an additional touch-action: none style property to work correctly under Android. I fixed it in the online version here. By the way, I also checked the JS viewer works correctly under iOS.
V6 beta 11 is working like a dream on OSX Mojave. Rotating the sky is fast and looks perfect in the preview window, but it seems using a rotated sky and light panels in the same project makes it impossible to render both at the same time:
Thanks for your report. The last image shows a rendering made with Enkonyito's plugin that doesn't take into account the rotation of the sky. He probably waits for the final release of Sweet Home 3D 6.0, to publish an update...
Indeed, although I started to integrate in the 1.6 beta version of the plug-in the changes made to SH3D-6.0Beta, the final release of the plug-in will be available only after that of SH3D-6.0.
EnkoNyito
This version brings translation updates in Portuguese, Spanish, Italian, Dutch, Swedish, Bulgarian, Greek, Russian, Vietnamese, Chinese and Japanese, including the translation of the 2 new options in Windows installer. Among small fixes, it brings also an update of Java 3D which new version 1.6.1 brings support for HiDPI screens when Sweet Home 3D runs with Java 10+. That's the reason why I provide also the JAR Executable version SweetHome3D-6.0.beta14.jar (25 MB) to let you test it with Java 10 or Java 11 under Windows or Linux, if you have a HiDPI screen (Java 3D doesn't work with Java 10 under macOS yet). I hope to get the 4 missing translation updates soon to release the final version 6.0 afterwards.
Today I downloaded and tested the beta 14 with Cecilia's 261 MB super-shed file. Using beta 11, I was able to make a photo render. Using beta 14 my computer stops rendering with the infamous red cross. Also, when trying to move the virtual my computer freezes. It also freezes when I try to use a separate window for the 3D image. All of these were possible with beta 11.
It looks as if memory management changed...? For the time being I will revert to beta 11.
Hans, if you use the Linux version you should change the launch script to add -Xmx... max memory parameter. I'm going to set it to -Xmx2g in the final version of the 64 bit version.
