Re: Sweet Home 3D 6.0
Thanks for your tests. I updated Windows installer to always display the installation folder screen with an additional option to uninstall the previously installed version. Download it from SweetHome3D-6.0.beta12-windows.exe (51 MB)
None problem for me with this beta 12 ! .
I think of an important thing In the software setup interface or software installation interface, add a memory size setting option. just like SweetHome3D.l4j.ini
The default use of 0.9G in software 32 is very small, and the 64 bit 4G is too small.Slightly more complicated rendering requires 10G's memory usage.
Maybe in a future version...
In 32 bit, a higher value won't work. In 64 bit, the default max is half of the available RAM.
Is max mem 14.2 Gb?
When run in 64 bit, the working limit must be the RAM size available on your computer when Sweet Home 3D runs.
To all <?> Ubuntu users who have problems running the beta version.
Thanks to the help of UbuntuBirdy I now can try the beta version 6. Here are the program lines you need:
[Desktop Entry] Version=1.0 Name=Sweet Home 3D BETA 611 GenericName=Interior 2D design application with 3D preview Generic Name[de]=Innenraumplaner Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview Comment[de]=Innenraumplaner zum Auswählen und Platzieren von Möbeln auf einem 2D-Hausplan mit 3D-Vorschau Path=/home/hans/SweetHome3D-beta611 Exec=sh -c "/home/hans/SweetHome3D-beta611/SweetHome3D-Java3D-1_5_2" %U Icon=/home/hans/SweetHome3D-beta611/SweetHome3DIcon.png StartupNotify=true StartupWMClass=com-eteks-sweethome3d-SweetHome3D Terminal=false Type=Application Categories=2DGraphics;3DGraphics; Keywords=interior;design;2D;3D;home;house;furniture;java; MimeType=application/sweethome3d; Name[de_CH]=SweetHome3D BETA 611
Note the following: - you can change the Name and GenericName to whatever you like - you can leave out the Comment lines - you can change [de] and [de-CH] to your own language - in the path names change "hans" to your own user name - make sure that the path name /SweetHome3D-beta611/ points correctly to your file (name and location) - open a Text Editor and copy the above text - save and name the file xxx.desktop where xxx is the name you want - then copy the script to /home/hans/.local/share/applications/ - this is a hidden file, so you need to do CTRL-H to show the file
- under the start button, type SW and SH3D should show up
Poland
So many new great features - oh, Emmanuel, please don't stop Due to "3d error" I had to install 6.0 beta 11 with "j3d.version=1.5.2" (Win 7, 32bit) and now it works nice.
Thank you very much Birdy!!! H
Glad I could help you, Hans.
There are two great programming highlights since time immemorial: once Linux and of course SweetHome3D! The result is a law of the universe: who's able to use SweetHome3D on a Linux-System, will be happy! And of course I will try to make as many people happy as possible by showing them how to use SweetHome3D on Linux.
A humble servant of the universe Pascal
Pascal
