Total posts in this thread: 2
Previous Thread This topic has been viewed 3953 times and has 1 reply Next Thread
brodbdie
measure and dimensions
at the moment a roomsize is measured mid of a wall to mid of a wall.
it would be helpful to change in the settings the measure method to border to border. If setting up a plan the base is the etsimate and this is based on inside dimensions.
[Mar 6, 2018, 12:07:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: measure and dimensions
Hum, sorry if you find me a little rude, but this subject has been discussed so many times that I prefer to let you explore the forum to get a deeper explanation.
By the way, objects called "rooms" are drawn corners to corners, then you can double click in them with the wall creation tool to draw walls around them.
[Mar 6, 2018, 11:10:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
