Total posts in this thread: 6
Previous Thread This topic has been viewed 3783 times and has 5 replies Next Thread
enkonyito
Resizable photo panel?
In this thread , it is discussed the possibility of changing the size of the photo panel.
The simple solution to make it resizable involves other consequences:
- deformation without respect of the ratio
- maximum size limit not taken into account
- truncated text when changing language
The solution to include this size change in user preferences does not seem possible from a plug-in.
Is it possible to change the size of the photo panel as needed?
EnkoNyito
[Feb 19, 2018, 3:55:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Resizable photo panel?
You can accept that the dialog box showing the photo panel is resizable by calling
dialog.setResizable(true);
in displayView method.
But of course, you main have to pay more attention to the layout of the panel...
[Feb 21, 2018, 8:53:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
That's what I meant by simple solution (manual resizing). wink
I noticed that there is a minimum size depending on LookAndFeel and language chosen.
On the other hand, is it normal that the maximum size is not taken into account when resizing?
Can you confirm that it is not possible to add a new user preference from a plug-in?
From your experience, what do you think of the option suggested by ndorigatti which is to add a button to change the size of the panel?
EnkoNyito
[Feb 22, 2018, 1:13:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
setMinimumSize was added to Window class in Java 6, but there's still no setMaximumSize method sad
There's no API in UserPreferences class to manage additional preferences, and nothing in the user interface for that. At the moment, this can be done only by subclassing this class in a derived version of Sweet Home 3D.
Managing the size of the panel isn't difficult, just call dialog.setResizable(true). I checked in PhotoPanel class and the photo component at the top will be enlarged accordingly. But the space at the left and right of the components at the bottom may look uselessly large if you don't manage their layout differently. It's probably the reason why I didn't make the dialog resizable.
An other option could be to add some zoom -/+ buttons to view details in the photo component, like in the background image import wizard.
[Feb 22, 2018, 2:19:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
I followed your advice by changing the layout of the components under the image preview.
with dummy label at left and right
without dummy label at left and right
Which one is best?
EnkoNyito
[Feb 24, 2018, 4:10:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Top version is best 😀
[Feb 24, 2018, 4:14:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
