Previous Thread This topic has been viewed 12330 times and has 2 replies Next Thread
eniavlys
Support for high sierra (10.13)
I'm balancing pros and cons in upgrading my mac to high sierra (10.13) right now. In Sweet home 3D's home page, it's explicitly said that support is provided for mac os up to 10.12. However, reading through the forum, I had the feeling that v5.5 actually does run on mac os 10.13.
So: do I have any chance of running a -kind of, even not 100%- stable version of sweet home 3D on mac os 10.13? Is there a specific beta version of sweet home 3D to use, or should v5.5 do a good enough job there for the moment? Or did I completely misunderstood things and there's for the moment no chance at all to get sweet home 3D to run on mac os 10.13? If so, do you have any idea on when sweet home 3D will run on mac os 10.13?
Thanks!!
[Oct 3, 2017, 3:09:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Support for high sierra (10.13)
Sweet Home 3D works under High Sierra. As explained here, the only remaining issue prevents to attach the menu bar of the application at the top of the screen on non English systems. So while Apple or Oracle is fixing this regression that happens on many Java applications, I programmed a workaround that displays the menu bar at the top of each Sweet Home 3D window. It's up to you to decide if you can live with that detail or not.
[Oct 3, 2017, 7:50:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
eniavlys
Dear Emmanuel,
Great! Thanks! Indeed I *can* live with this minor limitation, so I'll upgrade.
Thanks for your work!
[Oct 4, 2017, 1:12:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
