Total posts in this thread: 6
Previous Thread This topic has been viewed 6784 times and has 5 replies Next Thread
enkonyito
Curved line camera path
I repeat the problematic that has been discussed in this thread .
The drawing of the curved line is made with Arc2D from 2 main locations, the orientation of the camera and the center of the ellipse.
The intermediate positions are calculated using the parametric equations of the ellipse .
The correlation established with the SH3D coordinate system only works in certain cases.
Here is the part of the code drawing the arc for panoramic videos.
float x1 = cameraPath.get(i - 1).getX();
float y1 = cameraPath.get(i - 1).getY();
float x2 = camera.getX();
float y2 = camera.getY();
double trigAng1 = (Math.PI / 2) - cameraPath.get(i - 1).getYaw();
double trigAng2 = (Math.PI / 2) - camera.getYaw();
if (trigAng1 == trigAng2) { // straight line
g2D.draw(new Line2D.Float(x1, y1, x2, y2));
} else { // curved line
double chord = Math.sqrt(Math.pow(x2 - x1, 2) + Math.pow(y2 - y1, 2));
double radius = Math.abs(chord / (2 * Math.sin((trigAng2 - trigAng1) / 2)));
Arc2D circleArc = new Arc2D.Float();
double x = x1 - (radius * Math.cos(trigAng1));
double y = y1 + (radius * Math.sin(trigAng1)); // reversed axis in sh3d
double angSt = Math.toDegrees(trigAng1);
double angExt = Math.toDegrees(trigAng2 - trigAng1);
int closure = Arc2D.OPEN;
circleArc.setArcByCenter(x, y, radius, angSt, angExt, closure);
g2D.draw(circleArc);
EnkoNyito
[Jul 31, 2017, 8:25:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Curved line camera path
Could you give more details about when it doesn't work?
[Aug 1, 2017, 1:01:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Using the correlation found, the start angle depends on the orientation of the camera so sometimes the arc is badly drawn.
By discovering that we can use Math.atan2(y, x) to calculate the start angle from the position only, I will orient myself towards this solution.
EnkoNyito
[Aug 3, 2017, 8:42:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Problem solved.
EnkoNyito
[Aug 8, 2017, 8:07:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jdab
As a fan user of the video mode, I'd love to use these curved line in camera path. As well, a 360° rotation around a central point would be great !
Have these been integrated in SH3D yet, or will they be soon ?
Best regards,
[Dec 5, 2017, 11:39:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Since version 1.3 of the photo-video plug-in , the camera path can be in a curved line.
I do not know if this feature (or others) will ever be integrated with the standard version of Sweet Home 3D.
EnkoNyito
[Jan 26, 2019, 2:38:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
