Previous Thread This topic has been viewed 5143 times and has 2 replies Next Thread
GertHe
OBJ import problem
Hi, I (bought) and imported "Serve-over counters Sydney by Arneg 3D model" from cgtrader.com. I expected the delivery to be six different objects (six variations of the same service-counter). After importing the object to SH3D, it only appears as one object but including those six elements in one !?!? - so, unusable. Any ideas what has gone wrong here?
BR, Gert
[Jul 24, 2017, 10:45:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: OBJ import problem
Absolutely nothing has gone wrong. biggrin
One obj object = One object with sh3d.
You must import it with an another soft to dispatch the 6 objects (one per one).
To realize this, I use for example 'anim8or'.
[Jul 24, 2017, 12:50:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GertHe
Learning requires patience confused ... I managed to split the object by importing them to Rhinocero 5, then "select object -> Export Selected..."
Strange that PH3D refused to import the .DAE and .KMZ versions I had exported from Rhino ("format not supported"), but accepted .OBJ only. And that with not very much success either - as you can see in the pic (link)
compare what I originally thought I will have (to the left) to the mono-color result.
Guess Rhino export and PH3D import are not understanding each other.
...next need to try anim8or
[Jul 24, 2017, 2:46:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
