Re: Sweet Home 3D 5.5
On the Online version, these features are available in the contextual menu of the 3D view once you logged in.
Could you try again with the Online version after you activate Java console? If some text appears when you try to create a photo, I would be pleased you copy paste it here to help me understand what's going on.
Thanks for this helpful information. The error must be provoked by the fact that you use two monitors on your computer. I made the required change in source code to fix this bug. Too bad, I didn't fix it with the update I published on Saturday, moreover because you reported it on Thursday Shall I release a version 5.5.2 already?
I'm sure your karma is ok, but mine is in bad shape for this release, even if regressions are unfortunately very difficult to avoid after programming important changes.
At least, printing and print preview work for the 3D view, and creating images work if you turn off the second monitor. As the users with two monitors who want to create pictures in quality 1 or 2 might be quite rare, I might wait longer before releasing a new version. I fear that the upcoming macOS High Sierra might require some more important changes if Apple doesn't fix the current issues with Java programs (in the current beta, Sweet Home 3D free DMG version doesn't work and the paying version has some problems with the menu bar). So I would prefer not to release a new version each week!
[Edit 1 times,
last edit by Puybaret at Sep 11, 2017, 5:54:33 PM]
In case of need, I published a patch for this issue that was reported by another user. See Bug #780.
