Total posts in this thread: 98
Posts: 98   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 290787 times and has 97 replies Next Thread
Re: Sweet Home 3D 5.5
Do you mean the dialog box shown when you select Save & compress? Does it actually save the file?
No, it's about the progress bar which doen't move in all dialog boxes.
[Jul 31, 2017, 3:16:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Tonight, the version 5.5 Beta 9 brings translations of the new features in German, Swedish, Russian, Traditional and Simplified Chinese, and a few more improvements about horizontal rotations.
I also updated some demos to ensure they use the new features of the version 5.5, particularly for sloping roofs and doors on thick walls. Finally, I decided that the child piece with the biggest model size will be used as a sort criterion for rows containing a furniture group.
[Edit 2 times, last edit by Puybaret at Aug 4, 2017, 6:06:58 PM]
[Aug 1, 2017, 10:25:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FYI: beta9 doesn't resolve the anomaly about the progress bar which doen't move in all dialog boxes...
biggrin
[Aug 2, 2017, 9:17:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This is really a very small aesthetic bug that I can't reproduce on my Windows 10 computer. As long as the lengthy operation still works, I don't think I'll look for how to fix this issue. Probably a small problem in Java. Anyway thanks for reporting it.
[Aug 2, 2017, 10:43:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The version 5.5 beta 10 (Java Web Start, Windows installer and Linux 64 installer) comes with an update of Hungarian translation and a new look for the Furniture modification dialog box with different labels for the rotation around the horizontal axes.
Hope you'll find it clearer smile
I propose also a second installer for Windows with the version 5.5 beta 11, to get your feedback about how Sweet Home 3D works with the latest Java Runtime Environment 1.8.0_144, one year later I decided to stuck on JRE 1.8.0_51 to fix the crash problems encountered by some of you (the installer of Sweet Home 3D version 5.5 beta 10 still comes JRE 1.8.0_51). To check if it works better, I hope some of you will have the patience to test whether Sweet Home 3D 5.2 still crashes, then try the new version 5.5 beta 11.
Thanks for your tests smile
If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
[Edit 2 times, last edit by Puybaret at Aug 4, 2017, 9:17:04 PM]
[Aug 4, 2017, 6:06:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The Linux_64_installer links downloads a file called SweetHome3D-5.5.beta11-jre1.8.0_144-windows.exe.
Is that correct?
[Aug 4, 2017, 6:42:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry Hans, I fixed the link. Thanks for reporting the issue smile
[Aug 4, 2017, 7:28:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
...If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
Not chance !
It's now the second link for linux which is bad... biggrin
[Aug 4, 2017, 8:38:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fixed. Thank you. Bad luck wink
[Aug 4, 2017, 9:18:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Guess 'nothing to report' can also be a report smile Worked my way through the features and did some random editing, and Java Web Start seems to work beautifully under Win81. Thanks for the new features. ok
[Aug 7, 2017, 3:56:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
