Re: Sweet Home 3D 5.5
Thanks for your feedback.
harhouse, can you confirm that you tried the Java Web Start version 5.5 of Sweet Home 3D with Java 1.8.0_141 or higher (see About dialog)?
bdfd, can you describe step by step how to reproduce this bug with an example as simple as possible?
Well,
I began with a new project.
4 Walls (h = 2.5 m, width = 0.33 m) One door for entry A standard fixed window (vitrine in french) updated with dimensions : elevation = 1.1 m height = 1 m lenght = 1.6 m
Boom, look at the screenshot...
The wall keeps the old dimensions and the 'new' window has new location...
[Edit 1 times,
last edit by bdfd at Jul 28, 2017, 5:17:30 PM]
As I suspect your issue is due to a regression in the Beta 4, please try the Windows installer version 5.5 Beta 5 [link removed, see this message to test version 5.5 Beta 6]. Did you remove the SweetHome3D.l4j.ini file from your installation directory to check if the bug that prevents to show file dialogs in Windows 10 Creator update is fixed? I have an other idea to fix it, but would like to know how the first attempt worked for you, after harhouse's bad report.
[Edit 1 times,
last edit by Puybaret at Jul 28, 2017, 7:56:33 PM]
Great, it works fine !
ini file has been renamed.
Thanks for your test bdfd. Actually, I discovered an other small issue about the position of 3D models with an irregular shape, when they are rotated around horizontal and vertical axes. So please, test rather version 5.5 Beta 6 [link removed, see this message to test version 5.5 Beta 7].
[Edit 1 times,
last edit by Puybaret at Jul 30, 2017, 1:38:43 PM]
Thanks for your test bdfd...
De nada Manu.
1. I saw a strange thing when I ask 'Save & compress'. The progress bar into the box window didn't move.
Is it malfunction ? Not sure that beta6 is the cause...
2. Regressions a.The function 'Save as' breaks down sh3d. b. Save a rendering photo breaks down too...
Perhaps by giving a beta6.jar would be OK ?
[Edit 3 times,
last edit by bdfd at Jul 29, 2017, 10:51:23 AM]
1. The progress bar into the box window didn't move. 2. Regressions a.The function 'Save as' breaks down sh3d. b. Save a rendering photo breaks down too... Perhaps by giving a beta6.jar would be OK ?
Do not anything !
I resolved ALL the problems in renaming INI file in initiale name !
[Edit 2 times,
last edit by bdfd at Jul 30, 2017, 8:03:42 AM]
bdfd, thanks for your tests. Apparently the file bug in Windows 10 Creator update wasn't fixed in beta 6 yet, but I have other ideas, better than obliging users to add a SweetHome3D.l4j.ini file. Here's the version 5.5 Beta 7 [link removed, see this message to test version 5.5 Beta 10] that might fix that bug. It would be nice if you and/or harhouse could report if showing file dialog boxes works better in this version.
This Beta version brings also auto translation of furniture names found in demos, and the first translations of the new features in Italian, Portuguese, Dutch, Czech, and Polish made by the nice Sweet Home 3D contributors. Finally, it fixes again an other small issue about furniture rotated around an horizontal axis (a really tough subject as I feared!!!).
[Edit 2 times,
last edit by Puybaret at Aug 4, 2017, 4:08:22 PM]
bdfd, thanks for your tests. Apparently the file bug in Windows 10 Creator update wasn't fixed in beta 6 yet, but I have other ideas, better than obliging users to add a SweetHome3D.l4j.ini file. Here's the version 5.5 Beta 7 (Java Web Start version and Windows installer) that might fix that bug. It would be nice if you and/or harhouse could report if showing file dialog boxes works better in this version.
Sorry, No change (dialog box & save as) ! beta7 crashes too (without ini file).
[Edit 1 times,
last edit by bdfd at Jul 30, 2017, 5:59:15 PM]
bdfd / harhouse, please try the Windows installer of the version 5.5 Beta 8 without the SweetHome3D.l4j.ini file. I found an issue about how Java 8u51 handles Windows 10 version number and it prevented the correction that I programmed for file dialog boxes to work! Thanks for your patience...
[Edit 1 times,
last edit by Puybaret at Aug 4, 2017, 4:07:33 PM]
