Total posts in this thread: 98
Posts: 98   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 244342 times and has 97 replies Next Thread
Re: Sweet Home 3D 5.5
Tonight, the version 5.5 Beta 2 brings the other following features:
Don't work on my main PC too ! crying
When a exe release ?
biggrin
[Jul 25, 2017, 6:41:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The final release won't appear before a few days or weeks, because it requires some translations.
But as the version 5.5 is supposed to fix the bug that prevents to show file dialogs in Windows 10 Creator update, here's a Windows installer for version 5.5 Beta 4 [link removed, see this message to test version 5.5 Beta 5] to let you and others check this bug was fixed (you shouldn't need the SweetHome3D.l4j.ini file to set swing.defaultlaf anymore).
I updated also the Java Web Start version to version 5.5 Beta 4 after fixing some bugs I discovered on the management of groups which contain objets rotated around an horizontal axis.
[Edit 1 times, last edit by Puybaret at Jul 28, 2017, 5:45:21 PM]
[Jul 25, 2017, 8:25:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great, exe installation is OK !
first tries are good... smile
Pitch and roll on 'modify furniture' window are amazing !!! applause
[Edit 2 times, last edit by bdfd at Jul 25, 2017, 11:18:21 AM]
[Jul 25, 2017, 10:47:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The version 5.5 Beta 5 fixes a regression that appeared in the previous version on doors which are supposed to cut the both faces of walls.
I also tried to improve the new image shown in the Furniture modification dialog box, showing a chest:
instead of a cube:
I also renamed the new Virtual visitor selected at change preference as Select visitor in plan at 3D move, in the hope it will be easier to understand.
[Jul 26, 2017, 3:29:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
harhouse
Great work, great program. Sadly the new 5.5 beta 4 does not solve the crashing when using the open/save dialog popup in W10. The java webstart 5.5 you provided at the top of this threat does work however.
[Jul 28, 2017, 11:13:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shock Re: Sweet Home 3D 5.5
First anomaly for me ! biggrin
An existing project made with 5.4 and copy/paste and updated with 5.5 beta4 !!!
See the window and the wall (standard height 2.5 m) ???
=> All updated objects are wrong !
crying
[Edit 1 times, last edit by bdfd at Jul 28, 2017, 2:32:04 PM]
[Jul 28, 2017, 2:11:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback.
harhouse, can you confirm that you tried the Java Web Start version 5.5 of Sweet Home 3D with Java 1.8.0_141 or higher (see About dialog)?
bdfd, can you describe step by step how to reproduce this bug with an example as simple as possible?
[Jul 28, 2017, 2:56:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Well,
I began with a new project. biggrin
4 Walls (h = 2.5 m, width = 0.33 m)
One door for entry
A standard fixed window (vitrine in french) updated with dimensions :
elevation = 1.1 m
height = 1 m
lenght = 1.6 m
Boom, look at the screenshot... crying
The wall keeps the old dimensions and the 'new' window has new location... sad
[Edit 1 times, last edit by bdfd at Jul 28, 2017, 5:17:30 PM]
[Jul 28, 2017, 5:14:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As I suspect your issue is due to a regression in the Beta 4, please try the Windows installer version 5.5 Beta 5 [link removed, see this message to test version 5.5 Beta 6].
Did you remove the SweetHome3D.l4j.ini file from your installation directory to check if the bug that prevents to show file dialogs in Windows 10 Creator update is fixed? I have an other idea to fix it, but would like to know how the first attempt worked for you, after harhouse's bad report.
[Edit 1 times, last edit by Puybaret at Jul 28, 2017, 7:56:33 PM]
[Jul 28, 2017, 5:43:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great, it works fine ! smile
ini file has been renamed.
[Jul 28, 2017, 5:54:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
