I use SH3D on my windows 10 with inter i7, 8gb ram DDR3, but if I want render photo 1920x1080 it take approx. 20-25 minutes. I set .ini in folder with 4GB ram for JAVA. I checked this and JAVA use 4-5 gb of ram, where is the problem? Its really frustating. Before there is no problem with this. Thanks
Re: Too long time while rendering photo
There's no reason why the rendering process should suddenly slow down. You must have made some changes, maybe adding some lights or some complicate objects.
And we don't know how is the used quality : 1 (low), 2 3 or 4 (high) ?
[Edit 1 times,
last edit by bdfd at Jun 9, 2017, 6:28:22 PM]
OK !
To compare the calculation time of an old project without updates with the same parameters, you must restart a rendering with the old one.
=> Longer, same time or shorter (!?!) ...
To give your an idea, you can see in gallery section, several pictures (mine, Martinsk's pictures, ...) which have taken between 4 and 20 hours for the most beautiful...
