Total posts in this thread: 5
Previous Thread This topic has been viewed 4871 times and has 4 replies Next Thread
jimass
3D rendering - Where to change default settings
Hi, can you send me path, where to find file with Photo create setting. So every time when I will be rendering 3d photo there will be my options. For example width 1680px height 1120px, Time 5.30pm etc.
Thank you.
[May 31, 2017, 10:53:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D rendering - Where to change default settings
The default value of this parameters are directly set in the program : in HomeEnvironment class for photo width and height, and in Camera class for the time.
So, if you know a little Java and how to build a program from its source code, you can change these settings with no problem, otherwise I fear it won't be possible.
[May 31, 2017, 8:11:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jimass
Thank you! I'm not very good in java but I changed size of photo and time to 17:30. Can you pls advice me how to change date from actuall date to for example 15 July. Also I need uncheck Aplly proportions and Add celing light.
private static long midday() {
Calendar midday = new GregorianCalendar(TimeZone.getTimeZone("UTC"));
midday.set(Calendar.HOUR_OF_DAY, 17);
midday.set(Calendar.MINUTE, 30);
midday.set(Calendar.SECOND, 0);
midday.set(Calendar.MILLISECOND, 0);
return midday.getTimeInMillis();
Thank you very much.
[Jun 1, 2017, 11:01:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jimass
Somebody can help me please?
[Jun 7, 2017, 8:27:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I gave you the idea last time. Changing the date is about learning to use GregorianCalendar API and the other settings can be found in the code just by searching their name. Good luck!
[Jun 7, 2017, 10:47:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
