Total posts in this thread: 5
Previous Thread This topic has been viewed 2641 times and has 4 replies Next Thread
narnal
korea
cant not open, 'modify walls...' dialogue
Right click 'Modify Wall' on 'wall' and 'popup dialog' does not appear.
Click again and there is no response.
screenshot : https://i0.wp.com/www.dolzikoo.com/wp-content...size=1024%2C720&ssl=1
OS: windows 10 64bit.
[May 6, 2017, 9:12:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: cant not open, 'modify walls...' dialogue
Could you check if there's some error log that could explain your issue?
Please open a cmd window and run Sweet Home 3D redirecting errors to a file with a command like:
"C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2> Desktop\log.txt
If the file log.txt contains something, please post it here.
[May 7, 2017, 10:59:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Nio
I am also facing the same problem ...
[May 13, 2017, 3:00:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Nio
I get that log.txt file after I launch sweet home 3d by command prompt ....as you said..
[May 13, 2017, 3:41:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The log file you posted reports an error in the look and feel, and I'm not sure I can fix that.
Please, try to use a different Windows theme, or run Sweet Home 3D with a different look and feel by adding a file named SweetHome3D.l4j.ini in the same folder as SweetHome3D.exe and writing the following line in it (with the starting hyphen):
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel
Hope this will work...
[Aug 25, 2017, 6:54:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
