Total posts in this thread: 2
Previous Thread This topic has been viewed 3308 times and has 1 reply Next Thread
rdmhora
Brasil
Wall's axis change
Hello every one! When I'm going to draw the walls I type the size that I want, but when I draw the next wall the previous wall size change duo to thickness. This happens because the wall's axis is set in the center of wall. How can I change to be on the left or the right of the wall?
[Apr 25, 2017, 12:12:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Wall's axis change
Sorry, there's no way to change the central axis used to measure walls length. If you don't want to calculate the difference, a workaround could be to draw first rooms and double click in the room with the wall creation tool to create the walls around it. But this won't be a perfect solution either if the walls must have different thicknesses or if you want to draw more than a room.
[Apr 25, 2017, 7:59:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
