Total posts in this thread: 109
Posts: 109   Pages: 11   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 238432 times and has 108 replies Next Thread
hal9000
Spain
Re: Poor performance on desktop application 3D View compared to HTML5 viewer.
I installed the Windows 10 Creators Update and solved the problem. ;)
As bdfd said, not for me. I just installed the Creators Update and the 3d view is still slow.
[Apr 17, 2017, 11:15:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000, please install Java, download the Jar executable version of Sweet Home 3D, and run it with the following command in a cmd window:
java -Dcom.eteks.sweethome3d.j3d.version=1.5.2 -jar /path/to/SweetHome3D-5.4.jar
(to get easily the path to SweetHome3D-5.4.jar, just drag and drop the file in the cmd window).
This will run Sweet Home 3D with an older version of Java 3D. I wonder if it will work better in your case.
[Apr 18, 2017, 12:43:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dddstudio
Magyarország
I can confirm. Since the last Win10 update, SH3D became very slow. Unusable this way.
[Apr 18, 2017, 2:48:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dddstudio
Magyarország
I have tried it, but no good.
[Apr 18, 2017, 2:50:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Thanks Emmanuel, but no luck.
I just tried what you suggested, with both Java 64 and 32 bit and the 3D view is still "jumping" from a position to the next one as seen on the video. sad
[Apr 18, 2017, 3:57:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The number of users with problems grows up !!! sick
But "our international Manu" is going to find a good solution... raised eyebrow
[Apr 18, 2017, 5:04:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dddstudio
Magyarország
For additional information I have include that this exact problem first occurred around Mar. 17., I have immediately notified Emmanuel. After a few days and a supposed Win10 update the problem went away. But now it came back. I do not know what type of update messes with this. My problem only happens on my work computer. At home, there are no problems.
[Apr 18, 2017, 7:20:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
I just tried on a fresh Kubuntu 16.04 with the latest SH3D version and just the same (or even slower) than Windows with the 3D view, while the movement is also fluid in the HTML5 viewer.
Is there any way to use in the application the same rendering than the viewer?
[Apr 20, 2017, 9:49:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The HTML5 viewer uses an HTML5 canvas and is programmed in JavaScript, whereas Sweet Home 3D is programmed in Java. Even if it should be possible to view an HTML5 canvas in a Java application, it's the kind of mix I won't try. I hope to find an easier and more consistant solution!
[Apr 21, 2017, 12:05:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Thanks Emmanuel. It was just an idea to try and use an existing working 3D visualization, but I understand your point on mixing thinks not made to be mixed. tongue
[Edit 1 times, last edit by hal9000 at Apr 21, 2017, 12:46:56 PM]
[Apr 21, 2017, 12:46:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
