Total posts in this thread: 5
Previous Thread This topic has been viewed 4163 times and has 4 replies Next Thread
sergiopss
Generated Photo is always blank
After adding a room to my project, after that moment I can't generate anymore a photo or video in hight quality when using "Virtual Visit" view since the generate image is always blank.
If I delete the room is ok again.
Here is a print screen for best understanding: IMAGE
I've searched for possible fix but without results...
Any help?
Thanks.
[Mar 31, 2017, 4:39:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Generated Photo is always blank
Any help?
Thanks.
I had the same problem after adding a fairly large object. crying
We have thus reached the possibilities of the software (either in memory or in the number of objects present, ...).
You need to simplify your project...
[Mar 31, 2017, 5:15:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sergiopss
Hi, thanks for the reply but that's not a solution since I'm only making a simple prototype... I only have about 10 simple objects and this only happens when I add the room, even without textures.
[Mar 31, 2017, 5:43:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sergiopss
Hummm, my bad...
I just realize that my view probably was above the ceiling (can't realize that on the 3d view).
When rendering, it was rendering by beautiful white ceiling...
Problem solved!
[Mar 31, 2017, 6:09:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hummm, my bad...
Problem solved!
OK !
The center of the point of view had moved... laughing
[Mar 31, 2017, 7:29:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
