Previous Thread This topic has been viewed 26027 times and has 13 replies Next Thread
ejneafsey
SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20)
Running Xubuntu 16.04.
I downloaded new 5.3 version of SH3D. It gave me the 3D error. I then upgraded to latest Nvidia driver (375.20). Still received the 3D error.
Here is the full error message:
eneafse:~/bin/java/SweetHome3D-5.3$ ./SweetHome3D
com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7f4168178e90, context 0x7f41680152a8, drawable X11OnscreenGLXDrawable[Realized true,
Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@156d498a,
Handle 0x180009d,
Surface JAWTWindow[0x51134a51][JVM version: 1.8.0_112 (1.8.0 update 112)
JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 737 x 359 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x180009d, surfaceHandle 0x180009d, bounds [ 0 / 0 737 x 359 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 737x359], pixels[scale 1.0, 1.0 -> 737x359], visible true, lockedExt false,
config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0],
chosen GLCaps[glx vid 0x28, fbc 0xdf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 16/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x28],
encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0.0, unitID 0, handle 0x7f4168178e90, owner true, JAWTToolkitLock[obj 0x38b9192f, isOwner true, <fb2f30d, 70ecca68>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x28, fbConfigID 0xdf,
chosen GLCaps[glx vid 0x28, fbc 0xdf: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]],
awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,737x359],
surfaceLock <b66caa, 315a9ccb>[count 1, qsz 0, owner <J3D-Renderer-1>]]]
at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393)
at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:765)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:648)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:586)
at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4602)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2376)
at javax.media.j3d.Renderer.doWork(Renderer.java:881)
at javax.media.j3d.J3dThread.run(J3dThread.java:271)
Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics contextX11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2)
X11Util: Open X11 Display Connections: 2
X11Util: Open[0]: NamedX11Display[:0.0, 0x7f4168001620, refCount 1, unCloseable false]
X11Util: Open[1]: NamedX11Display[:0.0, 0x7f4168178e90, refCount 1, unCloseable false]
Don't know what to do next.
Thanks.
E.J. Neafsey
[Nov 24, 2016, 1:41:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20)
Please try also the SweetHome3D-Java3D-1_5_2 script available in the installer version.
[Nov 24, 2016, 10:13:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ejneafsey
Problem solved with the SweetHome3D-Java3D-1_5_2 script!
Thanks!
[Nov 25, 2016, 2:41:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your feedback.
It looks like I'll have to provide Java 3D 1.5.2 along with Java 3D 1.6.0 for a while with Linux sad
[Nov 25, 2016, 6:59:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rpax
Spain
Seems to be a problem with the onscreen rendering.
I'm Using Ubuntu 16.04.1 LTS 64-bit, and an NVIDIA Quadro K2100M.
It gives me the following error:
com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7f73c0196160, context 0x7f73c01a78d0, drawable X11OnscreenGLXDrawable[Realized true,
Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@8feadc3,
Handle 0x480009b,
Surface JAWTWindow[0x1bc19888][JVM version: 1.8.0_111 (1.8.0 update 111)
JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 749 x 373 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x480009b, surfaceHandle 0x480009b, bounds [ 0 / 0 749 x 373 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 749x373], pixels[scale 1.0, 1.0 -> 749x373], visible true, lockedExt false,
chosen GLCaps[glx vid 0x72, fbc 0x189: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x72],
encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7f73c0196160, owner true, JAWTToolkitLock[obj 0x3f6b4a2c, isOwner true, <bc669e9, 762b4de7>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x72, fbConfigID 0x189,
chosen GLCaps[glx vid 0x72, fbc 0x189: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]],
awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,749x373],
surfaceLock <77ba2b41, 11e94f54>[count 1, qsz 0, owner <J3D-Renderer-1>]]]
Try setting the flag
-Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true
. It should work.
@Puybaret: Debugging a little bit, seems that something is messed up in the interaction between the creation of the 3D Canvas and the new java3D libraries. I'll take a closer look at
Best,
-.Rafael.
[Dec 6, 2016, 8:05:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rafael, the report just says that the class of the displayed component is com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D and I fear the problem is somewhere else.
Did you try the SweetHome3D-Java3D-1_5_2 script available in the installer version?
[Dec 9, 2016, 6:49:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rpax
Spain
Yes, and it works fine. But I want to use java3d 1.6. With the offscreen it works, at least for me. Is anybody having this problem with the flag set?
[Dec 9, 2016, 7:03:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dgbutterworth
Hi, and thanks for your great works. I had and still have the same problem with a video related error in SH3D 5.3 - (running Mint 17.3) - that's referenced in this thread. Using the SweetHome3D-Java3D-1_5_2 script solved the problem and everything was great. (In fact - before 5.3, I could not load the program for a long time and was using the web start version - which was limiting.)
Maybe this too deeply buried to be noted, but I just wanted to note that I still have th same problem with version 5.4 - which is still resolved entirely to my satisfaction using the SweetHome3D-Java3D-1_5_2 script.
Thanks again. Shout if I can provide any additional info that would be helpful.
dgbutterworth
"... until you break it, you'll never know whether it needs to be fixed. so try harder."
[Feb 7, 2017, 7:14:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dreamcarrior
US
I want to report that using Fedora 25 64-bit version kernel 4.10.13-200.fc25.x86_64 #1 SMP with nvidia card also has the same issue. However, using the Java launcher is able to make it work.
Thank you very much!
[May 6, 2017, 3:38:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Start SH3D with SweetHome3D-Java3D-1_5_2 , that should solve your problem.
[May 7, 2017, 4:56:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
