Total posts in this thread: 226
Posts: 226   Pages: 23   [ Previous Page | 6 7 8 9 10 11 12 13 14 15 | Next Page ]
Previous Thread This topic has been viewed 715514 times and has 225 replies Next Thread
enkonyito
I started working on its new interface for adding the rendering engine selector.
There will no longer be the ambient lighting slider or the display of the estimated remaining time that is not very reliable.
The Enhance external brightness checkbox will be renamed Enable sky lighting.
The Advanced settings button would access the properties of the selected rendering engine.
All objects in ChristmasLights.sh3d have been matted to avoid differences in shininess between the renderers.
For the moment, the YafaRay rendering engine is not compatible with these light panels.
EnkoNyito
[Dec 22, 2019, 6:36:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I'm using your panel lights all over the place, so I guess I shall just have to be patient.
Please don't ditch this. It's not entirely reliable, but it's in fact fairly close to accurate under the right circumstanses.
It predicted 79 hours for rendering this image, and it took 72.
cec
[Dec 22, 2019, 8:31:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Ceciliabr
I hope that Emmanuel Puybaret will take into account my request concerning an xml example file using light panels, opaque light spheres and caustic photons because the documentation of YafaRay does not detail it which complicates their implementation.
Keeping the display of the estimated remaining time, it will surely be necessary to modify the size of the photo panel so that it is not too large on a standard screen.
Beautiful Christmas tree!
Enko
EnkoNyito
[Dec 24, 2019, 3:05:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
What is a standard screen? 1080p?
[Dec 25, 2019, 11:55:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
A medium-sized screen.
Finally, the height of the photo panel is acceptable while keeping the display of the estimated remaining time. ;-)
EnkoNyito
[Dec 28, 2019, 2:03:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
PhotoVideoRendering-1.9 plug-in
- added a rendering engine selector (simple photo panel)
- compatibility with the YafaRay rendering plug-in (version 1.0)
EnkoNyito
EnkoNyito
[Feb 13, 2020, 8:57:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Congratulations EnkoNyito! smile
If possible, I would suggest that you post a SH3D demo file in Ticket #18 that will show most of your settings (maybe with some explaining texts in the plan when necessary). The documents you wrote are certainly appreciated, but demos can help to show quickly how it works.
[Feb 14, 2020, 5:02:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Enko,
Indeed, beautiful and very practical. It works well under Windows 10 pro, will test in coming days, weeks.
Thank you very much!!! 🍾🍾🍾
[Feb 14, 2020, 8:33:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Emmanuel, Hans, thank you very much! wink
Here is a SH3D demo file for using the plug-in with new light sources and image-based lighting (sky with texture).
SunFlow rendering (Ambient Occlusion + sky lighting enabled)
EnkoNyito
EnkoNyito
[Edit 1 times, last edit by enkonyito at Apr 6, 2020, 4:50:55 PM]
[Apr 3, 2020, 9:37:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
For the opaque light panels, it was necessary to apply a specific material to them so that they work with YafaRay.
Regarding the demand for automatic light panels, those that are off during the day keep their glow effect. Is it annoying for you?
If this is too annoying, only an unviewable light panel will be available in automatic mode.
EnkoNyito
[May 25, 2020, 2:27:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
