Total posts in this thread: 226
Posts: 226   Pages: 23   [ Previous Page | 2 3 4 5 6 7 8 9 10 11 | Next Page ]
Previous Thread This topic has been viewed 872547 times and has 225 replies Next Thread
enkonyito
PhotoVideoRendering-1.6 plug-in
- compatibility with Sweet Home 3D 6.0 and higher
- management of new light sources
- use of a light panel as room ceiling light
- added Speed and Frame Rate fields in the video panel
- possibility to choose the type of path in the video panel
OtherLightTypes-1.1 libraries compatible only with this plug-in
- PointLight_type: 1 light point with modifiable color
- SphereLight_type: 3 light spheres with modifiable color
- TrianglemeshLight_type: 3 light panels including 2 with modifiable color
Available in the Light sources category.
EnkoNyito
[Oct 13, 2018, 10:04:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you. Important part of the 6.0 launch. Quick test looks good. ok
[Oct 13, 2018, 10:21:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi enkonyito.
Have to say i found these light sources far more user friendly, thanks for the work you put into them and 1.6
Here i have used 4 opaque panels @ 25% and 4 "unviewable" panels, these are elevated to 1100mm, set to 10% and light the ceiling.
Thanks again
[Oct 14, 2018, 1:44:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
smile Re: Photo-video rendering plug-in
Can not change the color of lights.
None problem for me.
Automatic and color work fine ! applause
[Oct 18, 2018, 9:28:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
Is this just imagination or does the new plug-in render much faster?
Pascal
[Oct 22, 2018, 3:00:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
biggrin Re: Photo-video rendering plug-in
Today I rendered 16 times to test the difference between the different items in "Advanced settings>Quality 4>samplerAlgorithm" option.
I found that "bucket" rendering is the best quality and takes up the least amount of GPU. "Fast" rendering is the fastest quality consuming GPU.
If you want GPU to take up a little more, I think there is only one way. Render with a fast rendered quadruple resolution. Then use software to reduce the screen size by 4 times.
Original image, not rendered
"bucket"-1000X500 Rendering time, 40 minutes
"fast"-4000X2000 Reduce size 1000X500 Rendering time, 26 minutes
The difference is only in the processing of light and shadow. Square rendering is more natural. But the rendering time for fast rendering is 40% less.
So I recommend
1.adding one in the option, 4x supersampling for fast rendering.
2.And render with smaller squares.
3.Support for rendering pauses.
4.And automatically save the file.
5.Allow rendering of 16000X8000 resolution
[Oct 22, 2018, 6:55:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Another important thing to forget is to add a "pause" button after the rendering starts.
The rendering time is very long and uses 100% CPU. If you encounter individual things at this time, you can't do it.
[Oct 25, 2018, 2:13:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
At this point, the plug-in will not evolve any more.
Compatibility with future versions of Sweet Home 3D will be maintained, as far as possible, for changes in rendering. (PhotoRenderer.java history )
Enko Nyito
EnkoNyito
[Feb 9, 2019, 1:43:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
While waiting for the next version of Sweet Home 3D, here is the latest beta 1.7 of the plug-in. This allows you to test the ambient lighting panels by activating "Add all ceiling lights" in the standard version of SH3D.
To view the location of panels in the plan using polylines, you can use this utility.
EnkoNyito
[Apr 25, 2019, 12:23:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Not sure, well no idea at all really, how much a plug can link with the main software, but, would it be possible to move the choice of having the ambient lighting on, and its slider, away from the render modification window and onto the room modification window.
This way each room could be controlled individually, on, off and brightness.
[May 5, 2019, 8:25:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
