Hello I'm working on extensive upgrades to PVR 2.8 If enough members of the community are interested, I'll gladly share it 😄
---------------------------------------- Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
Let's face it, Space Mushrooms do not appear to care about the people here, and this project is stagnant as far as I'm concerned. No prospect of any updates.
That fork by Dawid has had more commits over the course of a couple of weeks than the open source edition of SH3D has had in two years of SM ownership. I get it... they are a company and want to make a profit. Fine, but at least be honest and say so up front that there will be no more open source releases so we don't sit around here waiting for Godot.
If Dawid reads this next bit, don't take it personally. I'm just cautious by nature.
I compared his initial commit to my own 7.5 local clone and can confirm it matches identically. I think there is one new file just describing what he is doing.
I then had Claude scan for anything in his following ~60 commits for anything troubling, and it all came back clean.
SweetHome3D only works with groups in the obj files but it can import obj files that only have objects (o) in the file. There is no need to change the export to objects for Blender, in Blender you can choose to split into groups when importing (if there are groups) or only import objects (o) or both. The same with export from Blender, you can choose to export groups and/or objects. If you have downloaded a model that only has objects and no groups you can simply import it in SweetHome3D and export it again. SweetHome3D will export it with groups per material. The g and o groupings are just that, groupings. If you remove them all you still have a valid file that you can import.
If you have created a model with deformation strings on the g lines you can import these in Blender with the switch to import groups (and not objects). Remember to also export groups and NOT objects or you will loose your deformation strings. I found Blender an excellent alternative for adding/editing deformation strings instead of the plain text editor.
@Keet I think you're talking about my patch. The issue I had was that I wanted to use my entire SH3D plan in Blender. The options were:
A single monolithic mesh with a horrific texture map, or
A bazillion meshes with no structure and no sensible naming.
This patch makes the import into Blender much better. See the image at https://github.com/laszukdawid/DobryDom3D/issues/57 where you can see hierarchical structure with dedicated collections for elevations, levels, walls, ceilings, floors and groups. Makes working with a whole house in Blender about a thousand percent easier.
Ah yes, that is different. The split for a complex export to Blender looks much better with the patch.
