I'm missing the German translation. SH3D is version 7.3. The button and the check box are in English. The dialogs are also in English.
This is a regression due to careless copy/paste. File to replace in the archive to take full account of the German translation.
Additionally the check box is active and disabled. In previous versions it is inactive and enabled.
This is the normal behavior of this new version which is intended to be most similar to that of Sweet Home 3D. By default, sky lighting is implicitly enabled and non-editable in aerial view while it is disabled in virtual visit.
If this is too disturbing, I created a small plug-in to reproduce the properties of the aerial view camera in that of the virtual visitor.
EnkoNyito
Bonjour enkonyito.
Une petite question. J'ai installé la version PhotoVideoRendering-2.8-windows-x64.zip sur mon PC qui avait avant la version 2.7. Et j'ai remarqué que l'éclairage du ciel était activé par défaut sans possibilité apparemment de le désactiver.
Est ce normal ?
Merci et encore bravo pour toute votre implication pour Sweet Home.
From the message of Enkonyito posted just before yours, sky lighting is implicitly enabled and non-editable in aerial view while it is disabled in virtual visit. So you should use Virtual visit mode to unselect this checkbox.
For your information, Enkonyito requested to disable his account on this forum and at SourceForge.net. This probably means that we won't see him contributing to Sweet Home 3D anymore!
I'm very sorry to hear that we lost such a valued and appreciated member. There must have been more than just his frustration with sourceforge because Emmanuel offered to host his plugins if sourceforge continued to give problems. I have offered him the same.
Brasil
Sorry for the doubt, but in OtherLightTypes version 1.5 what is the real difference between "automatic", "daylight" and "permanent". In rendering tests I didn't notice a difference.
