@Waldemar.Hersacher
You can send me your translation to integrate it into the next version of the plugin and if there are any changes, I will get back to you.
In the meantime, you can also share it on the SH3D forum and possibly on SourgeForge if you have an account there.
EnkoNyito
Germany
I have send the file to enkonyito and uploaded to SourceForge.
MSI GP60, Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy, SH3D 7.5 with Photo-video rendering 2.8
Regarding the issue raised here, would you prefer to keep the current plug-in menu or have it use the 3D View menu?
EnkoNyito
Germany
I always used the plug-in menu. I used the 3D View only for fine adjustments for the positions. I have positioned the visitor in a door. In 3D View I could look into the room but the photo was complete black. I discovered that when the nose of the visitor icon is within the room and the coordinates are within the wall the 3D View will not be black but the photo. I need to move the visitor into the room (mostly 3 or 4 mouse wheel ticks) to have a not black photo. To check the correct position I started a low pixel (320 x 180) rendering. I have the 3D view always in a separate window occuping the full screen so starting from 3D View will be a little bit easier.
Germany
I also save the camera positions. My work flow is to store all camera positions using the low pixel rendering and do the full pixel rendering afterwards. Since the rendering takes up to an hour and I will not let the laptop run over night it is easier to start the next day from the menu. You should keep the plug in menu entry. Other texts are also affected.
After noting that the plug-in actions were not accessible by right-clicking in the 3D view even if they had been added to this menu, your remark and that of Puybaret concerning the use of a standard user confirms that the current menu is maintained.
This is an inherent behavior of Sweet Home 3D.
EnkoNyito
initialization with Sweet Home 3D default rendering settings
basic components common to Sweet Home 3D
dynamic translation after language change (except menu)
German translation by Waldemar Hersacher
The ApplicationPlugin_en.properties template file is included in the zipped folder.
EnkoNyito
[Edit 1 times,
last edit by enkonyito at Jan 27, 2024, 3:03:43 PM]
How do i get the "Create photos at points of view" multi-photo interface to allow selecting the time of day to use in the render? I have tried sliding the selector to level 3 and level 4 and no advanced settings show up like they do for single photo option.
The "Create photos at points of view" panel allows you to automatically create photos from previously stored points of view with the date, time and the chosen rendering engine. So you need to set these settings in the "Create photo" panel first before storing the desired points of view.
EnkoNyito
Germany
Hello! Sorry if I am writing in a wrong section of forum, but I have some problems with Light Panels plugin, Photo-video rendering plug-in or both of them. I have tried to use Light panel to highlight screens of my devices but for some reasons Light Panels not worked as I expected, It lights like panel highlighted with normal bulb not like evenly illuminated panel. Maybe there is a problem with incompatibility of different versions of plugins and SweetHome3D version. Or maybe I am doing something wrong ))) Example of render and all important info about system, plugins and render settings are on my screenshot. Many thanks in advance for any help ))
