Total posts in this thread: 226
Posts: 226   Pages: 23   [ Previous Page | 8 9 10 11 12 13 14 15 16 17 | Next Page ]
Previous Thread This topic has been viewed 693300 times and has 225 replies Next Thread
I already tried that.
Removing java is really not removing Java, so you still get the same message.
Either Java behaves like some kind of virus that can't be removed, or it leaves a script that prevents installing of older versions.
What bugs me tho, is that v6.3 should ask for an older version of Java, when v6.0 runs perfectly with the latest version of Java.
[Jun 13, 2020, 10:06:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Problem partly solved, in my case. I did another try, downloaded and followed instructions and opened it. No problem. Everything works with Catalina. The only thing I did different was to open SH3D before moving it to the applications folder.
But the main problem still exist. Yafaray v 1.3 does not work on any other OSX version.
[Jun 14, 2020, 8:46:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry,
I was too quick about Catalina: Yafaray 1.3 worked once. After changing the xmx to 32g, it no longer works. Changing back does not help.
PVR 1.9 works perfect
[Jun 15, 2020, 11:49:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Ceciliabr
...and YafaRay 1.3 does not work on my Mac 6.1 with Mojave 10.14.6
@Xiste
Which version of the YafaRay rendering plug-in works properly for you?
EnkoNyito
[Jun 15, 2020, 7:04:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PVR1.9 works, so the version you used when creating PVR1.9 is the one working for me.
It seems like the trouble with yafaray 1.3 comes when increasing xmx memory.
[Jun 15, 2020, 9:47:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The PhotoVideoRendering-1.9 plug-in uses the YafarayRendering-1.0 plug-in.
Does version 1.1 or 1.2 of the YafaRay plug-in work too?
EnkoNyito
[Jun 15, 2020, 10:48:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I don't know. I only use PVR.
Where can I download them? It seems only 1.3 is available for download.
[Jun 15, 2020, 11:45:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Forum links to download versions of the YafarayRendering plug-in:
- version 1.0
- version 1.1
- version 1.2
EnkoNyito
[Jun 16, 2020, 2:14:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I have now tried all 3 versions with SH3D 6.0 6.1.2 and 6.3.
The only way I can render with yafaray is with PVR 1.9.
The logistic problem here is that there's no way of telling what version of yafaray is actually loaded, since it's only possible to replace the current version with the new,
and I have no way to verify that the replacement has actually taken place, and that no remnants from the other versions are left in some hidden cache or settings file.
This makes it impossible to get qualified results.
I'm really most happy with PVR 1.9 and SH3D 6.0. It's a stable combination for OSX 10.13.6.
[Jun 16, 2020, 8:24:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
You can also find here the direct download links for the YafarayRendering plug-in versions.
If several versions are installed, only the last one is taken into account.
Remember to install only one version at a time, removing the old one.
You can check the version in use in the "Plug-ins" section by clicking on "Help -> About... -> Libraries...".
EnkoNyito
[Edit 1 times, last edit by enkonyito at Jun 18, 2020, 3:27:23 AM]
[Jun 18, 2020, 3:24:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
