Previous Thread This topic has been viewed 3836 times and has 2 replies Next Thread
ITGreen
Walls
Please help... I am attempting to create a patio and the program keeps building walls around it. How do I prevent this?
[Nov 16, 2016, 10:34:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Walls
This all depends on the patio really, whether it is just a paved area outside a building, whether it is raised (or the plan has levels), whether it has a roof/columns etc.
And it is a bit odd that walls should be 'built by the program', if so, you could just delete them (or adjust the height of the walls? So maybe there is something here I miss. Anyway - assuming a simple patio in the form of a paved area outside:
1) Either just use the room tool to draw your patio on the ground,
2) or (especially if you have rounded parts) outline the patio with walls that connect around the surface, double-click with the room tool inside to create the 'room' (surface), and delete the walls (or just adjust their height down).
[Nov 17, 2016, 7:36:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Walls
The better is 2 pictures.
One of SH3D (bad result) and the second (example found on the web) that you want to realize... smile
[Edit 2 times, last edit by bdfd at Nov 17, 2016, 12:04:08 PM]
[Nov 17, 2016, 12:01:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
