Re: 2040 : Mars Two
D 200
Three images before, you saw the six grouped shields.
They served as a roof for laboratories or warehouses. The astronauts were helped by 'the lifting module' also called crane.
The External walls have been made with martian sand. The central building has an air lock and is in communication with all five other buildings.
Re: 2040 : Mars Two
Night 1920 x 1080 in Q4
Re: 2040 : Mars Two
Now that the adventure starts on Mars, I would be happy to read more about it. How long do days last on Mars? Are there some "seasons"? What gravity? No risk of big winds or radiation? What components can be found in Mars atmosphere?
Re: 2040 : Mars Two
Yes Manu, what does 'Goo...e' say ?
Mars: fourth rock after the sun, between () Earth to compare, Radius: 3,396 km (6,378) Distance: 1.5237 AU (1) Rotation: 24h37mn (23h59) Period: 686.96 days (365.25) Gravity: 3.71 m/s (9.81) Excentricity : 0.0934° (0.0167) Inclination : 1.85° (0.0001) Obliquity: 25°19'=> four seasons (23°26') Satelittes: 2, Phobos & Deimos (Moon)
Risk of big winds : All is anchored on martian ground but dusty is little, be careful for joins.
Radiations: 2 sorts, solar and extra-solar. A special part of Habmod contains a strong tank which produce magnetic field which protects the crew when there is an alert.
Components can be found in Mars atmosphere: CO² which becomes O² CH4 or H²O becomes H²...
Components can be found in Mars underground: Ice, salted water, mineral salts, ...
Little technical spécifications of the updated solar module.
Mars two has two main solar modules, one for base camp and the second for the future reactor (which will make propellant to MRV).
[Edit 2 times,
last edit by bdfd at Oct 11, 2016, 10:56:23 AM]
Re: 2040 : Mars Two
So Mars One was in Orson Welles crater (purple cross bottom Xanthe), Mars Two is in Taytay crater(green cross bottom Pathfinder site) near river of Ares vallis.
Follow the black arrows.
Mars's map download HERE
[Edit 1 times,
last edit by bdfd at Oct 10, 2016, 8:36:17 AM]
Re: 2040 : Mars Two
D 210
Here one of the 'big box' which contains all other rovers. It has been divide in two sections to repair them and their storage.
Between two you find an air lock for the crew.
[Edit 1 times,
last edit by bdfd at Oct 11, 2016, 11:58:57 AM]
Re: 2040 : Mars Two
Same location at midnight.
Re: 2040 : Mars Two
Thanks Aeowyn.
D 211
Here a view of the base camp in afternoon.
[Edit 1 times,
last edit by bdfd at Oct 12, 2016, 9:51:43 AM]
Re: 2040 : Mars Two
The night falls on the base camp.
The next works are the radar and antennas to communicate in high debits...
[Edit 2 times,
last edit by bdfd at Oct 12, 2016, 7:46:40 PM]
