Re: 2040 : Mars Two
Parachutes are go and two engines are ON. They use mixing methane/Oxygen (CH4/O2) like a good old gas stove...
Slowly, the ground approachs.
1920 x 1080 in Q4 without 1.3.1
Mars is OK for the module habitation !
Next step : humans.
Re: 2040 : Mars Two
Here technical specifications of habitation module v2.
1900 x 1400 in Q4 without R1.3.1
If a storm occurs (I saw the movie 'The martian'), an anti-tilt system is set up. 4 cables out of the fifth floor (light gray, base of roof) and will be planted in the ground (like harpoons) ...
This module has five levels (with descent engines). 1st : Airlock and a rear cargo 2nd : technical part 3rd : living and sick bay 4th : bedrooms 5th : roof (upper airlock, antennas, parachutes, ...)
It can support 11 people ! It is equipped with 4-wheel drive to adjust its position.
Re: 2040 : Mars Two
D 188 : The D Day !
Departure begins...
1920 x 1024 in Q4 without R1.3.1
All 11 members of crew are aboard. Look at simply inside MRV v2 :
4 in cockpit and 7 under head (lying 45 °).
side view
The order to come in : The three first passengers in lower armchairs, The next four in upper armchairs, The two external astronauts in cockpit and finally The chief and the pilot in last (central location)...
Red : air lock, Grey : Dashboard, Green : cockpit, Blue : 7 Passengers (2 lines of 3 + 4 at different height. Yellow : technical storage, Dark blue : life support, Purple (rear red) : toilets, Rose : technical part, Cyan : engines & tanks Brown : main thrusters
[Edit 2 times,
last edit by bdfd at Oct 3, 2016, 7:13:40 AM]
Re: 2040 : Mars Two
Passengers must be impatient to land! Good idea to use transparency for such a small space
Re: 2040 : Mars Two
A hot moment for the crew and 30 mn after the Space center on Earth...
1024 x 800 in Q4 without R1.3.1
Heat shield is gone, like MRV the temperature descents, parachutes are open ! 1920 x 1080 in Q4 without R1.3.1
Re: 2040 : Mars Two
Slowly crew arrives on martian ground...
Re: 2040 : Mars Two
Touch Down !
"Hello Earth, Condor is on Mars ! " Quicky from Hermes... 30 mn later from Earth...
Re: 2040 : Mars Two
Yes, but some jerseys well sweat !
Here is the First interior view of this project. 1024 x 768 in Q4 without R1.3.1
Light is green, the second astronaut prepares his output from air lock...
Their priorities : 1. Prepare Habitation module, 2. Install Solar modules, 3. Go out the rover to take all members of crew...
[Edit 1 times,
last edit by bdfd at Oct 6, 2016, 6:08:28 AM]
