Re: 2040 : Mars Two
Here is one of the largest modules: the Docking module.
Its shape is square.
As usual, the markers are: green for the front and red for the rear.
It consists of 4 docking ports (MRV, Habmod and 2 Matmod) and 2 lateral outlets for MMU.
Front
All spacesuits are grouped in this module (except those of the pilot and co-pilot).
Middle
2 interior airlocks are arranged at the ends of the module. They are equipped with transparent walls.
Rear
It also manages with 2 robotic arms traveling 360 ° around the module for external equipment.
2 observation domes are present in the high and low front parts of the modules.
The 3D model is HERE
Re: 2040 : Mars Two
D 260
Come back to Taytay crater.
1920 x 1080 in Q4
All humans build the base camp in its phase II.
The printer 3D is operationnal. They are helped by a new crane entirely built by the printer 3D during the exploration.
There are true mountains in far horizon to delimite the crater all around base camp.
[Edit 1 times,
last edit by bdfd at Dec 11, 2016, 9:42:03 AM]
Atlas allows to take 2 types of materials. Heavy weights with crane and lighter boxes with clamp.
Depending on the weight lifted, weights can be added.
[Edit 2 times,
last edit by bdfd at Dec 13, 2016, 7:41:38 PM]
Re: 2040 : Mars Two
Thanks for showing the modules in 3D Fortunately, you posted them at the moment I was updating the Export to HTML5 plug-in, so I could try to improve the (very very) bad load performances of some scenes. Actually, this was due to an unoptimized management of 3D lines. As your 3D models have a lot of contour lines, this ended to a very slow program.
Re: 2040 : Mars Two
Thanks Manu, It's really faster now !
D 270
Main entrance is finished.
1920 x 1080 in Q4
The crew has built airlocks and must install air conditioning.
The large rocks and pebbles have been removed from the site so as not to hinder the rovers.
[Edit 1 times,
last edit by bdfd at Dec 14, 2016, 7:25:06 AM]
Re: 2040 : Mars Two
Here are pictures from the front of the accomodation's ring.
Front (green) 1024 x 768 in Q4
Rear (red) 1024 x 768 in Q4
This part of the vessel allows the refrigerated storage of food.
Nederland
Re: 2040 : Mars Two
Nice work i like it
Btw nice airschrubers in the back of the modulen
Re: 2040 : Mars Two
Thank you FDpaffie.
I come back for the comfort of the crew. In space like on Mars, the crew must have a intimate cabin.
I was inspirated by the Universe of Star Trek. This drawing picture shows us a double cabin with desk from USS Defiant.
Here a picture from TNG series inside a runabout of Danube class.
With these, I built a simple cabin which can have a second upper. 1920 x 1080 in Q3 (to see more détails).
They are going to be installed in ISS Hermes and the Habmod module. Length = 2.0 m Height = 1.5 m Width = 1.05 m In light gray in front of the top right cabin, you can see an escamotable door to sleep without noise...
Re: 2040 : Mars Two
We continue with the most important and the hardier : The Accomodation module.
I made two models : the first is empty (3.7 MB) to can upload it in 3D the second is full (20 MB) to take rendering pictures...
Firstly, here the specifications
In the case of solar eruptions, crew can go to garden to protect themself between shielded walls and tanks of water.
Top of the ring is the Entertenment room Bottom of the ring is the living, kitchen Left of the ring is the male bedroom with its bathroom Right of the ring is the female bedroom with its bathroom.
Imagine the difficulties to create the accomodation ring with SH3D... The central node with 6 entries/exits, the lights, the airlocks, the scales, the portholes,... all in this particular shape.
To create the good conditions, the ring turns at 3 RPM.
[Edit 1 times,
last edit by bdfd at Dec 17, 2016, 7:36:44 AM]
