Re: 2040 : Mars Two
Here are the views of the third part (v 1).
Internal dimensions : L : 2.8 m W : 2.3 m H : 2 m Surface : 6.45 m² Volume : 12.9 m3
Rear
Front 1920 x 1080 in Q4 with R1.3.2
Tchang and Winnie take a pause. The seats can be used as berths. The lower (under seats) and upper cupboards contain spacesuits.
Re: 2040 : Mars Two
Pierre, Tchang and Winnie have finished to install the drill.
1920 x 1080 in Q4
The drill is ON. After few meters of sand, the ground is made of sediments.
UPDATE !
Who did see THE difference ?
Found ?
[Edit 2 times,
last edit by bdfd at Nov 12, 2016, 8:04:12 AM]
Re: 2040 : Mars Two
lol .. wheel tracks in the sand
Yes ! Nederlands 10 points...
are u gonna make a movie next bdfd ??
Oh no, I just acted as a consultant for NGC...
Re: 2040 : Mars Two
D 249
D Day, in this morning, the exploration crew and its drill discover salted water...
1920 x 1080 in Q4
It's a success, now they must analysis the water. On site, temperature is equal to 10° C in summer and the pressure is equal to 6 millibars, so in these conditions; the water evaporates by direct boiling. The geyser must be stopped. The depth was 80 m, it may be an old water table...
For amators, you can read HERE .
[Edit 2 times,
last edit by bdfd at Nov 13, 2016, 8:26:23 AM]
Re: 2040 : Mars Two
The astronauts installed a plug and its 2 expansion tanks (cyan) in case of overpressure. The whole is fed by a solar panel.
1920 x 1080 in Q4
The information reached the base camp, Hermes in orbit and then all the media on Earth.
On Earth, scientists have announced that they have finished the new "EM-Drive" engine capable of doing Earth-Mars in 70 days instead of 180... No fuel or oxidizer required. This engine has been studied since 2016.
Links : Here with video and There
Re: 2040 : Mars Two
Meanwhile, at the base camp, the group ends the foundations of the base with 'martian concrete'.
1920 x 1080 in Q4
For this, they needed sand, water, regolith, pebbles, metal structure and a high pressure pump mounted on a rover named 'Bowie' and a crane module named 'Atlas'.
Re: 2040 : Mars Two
D 250 - ED05
'Water site' is secured. After all these facts and a good night, crew goes up the river to the plateau.
1920 x 1080 in Q4
The river decreases in size so, the drone is there to guide the crew.
